3 members (linklaw, +8Rich, Adam12), 286 guests, and 44 robots.
Adam12 66
+8Rich 64
John V6 61
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,372
Members9,215
Rbt Aero8, Salmon, stevends
Page 4 of 5 1 2 3 4 5
KennyW Offline OP
Snap, what you have started was exactly the same as my car which is a 2014 GDI.
Last Friday I spoke with a well known and knowledgeable Morgan mechanic who informed me that in the past he had to return a few ecu’s to MMC with similar issues. Armed with that piece of information I called the factory on Monday and was asked to bring the car in for them to have another look and to leave the car with them for a few days. Bearing in mind this is the 3rd time they had the car I was not overly confident in their mapping.
One thing I did this time round was to take a video of the car hunting upon cold starting which they took a copy of to come up with a remedy.
Anyway, I am very pleased to confirm that the car is now running so much better including a cold start this morning, it only took 6 months of perseverance! When picking up the car at MMC yesterday I was informed that they had found a compatibility issue with the base mapping coupled with the Clubsport mapping. Surprised this was not found at my previous visit but hey Ho it’s a Morgan.
To resolve the mapping issue they installed the latest base map to my early GDI map then installed the latest version of the Clubsport as an overlay. If you have an early GDI ? then this is what could resolve the problem. Best of luck and let me know how you get on.
Cheers Ken
Ken,
That's interesting, although so far this summer it's not been cold enough for it to be a real problem.
Cheers
John.
Kenny ,so glad you have got it sorted,its very difficult untill you know someone else has had the same problem. Any chance you could PM me with your full name,and tell me who you spoke to at MMC,and who did the sorting out, as I plan to phone them on Monday to ask them to sort mine out. How long did they have the car for ,although im not that far away from Malvern, very many thanks Duncan
duncan series 1 climax, TR +4, plus 4 GDI
SSL F&R suspension
If any body has had problems with the car after the clubsport remap,speak to Mark in service,as I have just taken my car back in .they took the original early GDi mapping off the ECU and put on the later GDi map and then reinstalled the clubsport flash,and now everthing is ok, no more problems,good result
SSL F&R suspension
Finally other people with the same problem! Knew this was a mapping issue from the start - we had the remap in January and it's been an issue ever since. Even got as far as looking into aftermarket ECUs and custom mapping to cure the issue but cost prohibitive! Will get onto Morgan Service today and see what can be done! Thank you guys!
Duncan: Do you have a source for the 2020 GDI (Plus 4) re map? (Clubsport) I’m in the U.S. and the dealer is 85 miles away. L.suglia@verizon.net. Thanks, Larry
On the subject of aftermarket engine management, while I have the earlier port injected Duratec HE Plus 4 rather than the GDI Duratec being discussed here, the following may be of interest?
As we all know the four cylinder Duratec engine has excellent tuning potential, its actually one of the key reasons I hunted down a port injected Duratec Plus 4 as I could see the potential of the platform.
However, after buying Monty last summer it soon became clear the Mk3 Ford Mondeo Visteon ECU used by Morgan was going to be the limiting factor influencing my development plans for the engine in my Plus 4. I spent some considerable time and effort studying what could be done with the Ford ECU but could neither find an 'HPTuner' type software solution to give me comms with the ECU, or indeed anyone in the engine mapping industry who was able to convince me they could genuinely live map the ECU with the car on a rolling road.
For the record, the only option really available for Duratec Plus 4 owners with the Ford ECU is a simple reflash suitable for the basic stage one type upgrade of adding a better exhaust manifold design and less restrictive exhaust system, a GDI Club Sport reflash if you will.
Now, as my development plans involve Newman stage two cams plus a better breathing custom fabricated inlet manifold, and these changes in addition to the Plus 4 Super Sports replica manifold and exhaust system I've already had built and am enjoying, it became clear I was going to need better control over the fueling and other parameters to make my inlet manifold, cams and exhaust tuning package come together to deliver their full performance potential safely and without risk of running lean.
Having now accepted the Ford ECU had to go, and as I have previous experience with aftermarket engine management installations using ECUs from Canems, Megasquirt, Emerald, MoTec and Haltec, I started to look at options for my Morgan, after a considerable amount of research I've just pulled the trigger on is the following Plug & Play (PnP) solution from Ecumaster:
This is not simply the patch cable arrangement we find with typical PnP ECUs, as we can see from the above images the solution from Ecumasters takes the PnP concept one step further by installing their highly respected EMU Black ECU and the patch cable inside the gutted enclosure of a Mk3 Ford Mondeo Visteon ECU. What you end up with is a fully mappable aftermarket stand alone ECU that's externally indistinguishable from a factory Ford ECU, and one that connects directly to the existing Morgan harness.
With Mk3 Ford Mondeo Visteon ECU's available for as little as £15 on eBay it's not only an elegant solution but a cost effective one too. We are currently going through the process of integrating the Caerbont instruments designed CAN interface found on the Duratec Plus 4 to ensure elements carried on the network such as the lower dash warning lights (ignition, seat belt, handbrake warning lights etc) and the rev counter all work as they do with the Ford ECU, the Ecumaster engineer is in communication with the electronics engineer at Caerbont instruments to ensure this minor challenge is fully resolved as they've done many times before when designing their PnP ECUs for Lotus, BMW, Ford, VW and Honda vehicles..... etc, etc, etc.
After that, the benefits of the setup will be considerable as an aftermarket ECU puts all the control lost with the Ford ECU right back in my hands and those within the large and ever growing network of professional tuners experienced with the EMU Black and all the other engine management solutions from Ecumater, at £1,250 the cost is quite affordable too.
Given this post looks like it goes back some time, if people are still struggling to find a solution to their frustrations with Morgan's Club Sport tune perhaps once we've overcome the CAN challenge the EMU Black PnP could be a solution worth considering? Saying that, I was told that Morgan used an MBE ECU of GDI Plus 4? If that is correct you GDI guys have already effectively have an aftermarket ECU, although it's probably a locked version?
Interestingly Caterham also use a locked MBE, so what Caterham owners tend to do is replace the factory MBE with an unlocked version of the exact same ECU and then have it mapped by someone like SBD motorsport:
https://sbdmotorsport.co.uk/product-category/ford/duratec/
I appreciate the Duratec engine Caterham models are all port injected and use a cable throttle, however, for GDI Plus 4 owners it could just be a case of plugging in an unlocked MBE ECU and paying a competent MBE tuner to build a direct injection Drive By Wire calibration that solves the issues you guys are reporting with Morgan's Club Sport tune?
Monty,
My understanding is that the GDI ECU is a version of the MBE9A6 which already has DBW and DI. However people that know a lot more than me about these things have said it is not a straight swap. I have tried to purchase the mapping kit from SBD and they refused to sell me one. I also know that when my car was on the local RR dyno, the operator who has the correct kit connected his laptop to the car but only some of the data was visible and other data was “strange” as if the addressing was not correct. The map is locked so he could not take a copy of the file.
So yes I would like to have an open ECU on my GDI but I don’t think there is an easy way to achieve it. Obviously if one rips all the wiring out and starts again anything is possible but as my car only has a major problem when cold starting so it's just easier to live with it.
Cheers
John.
Agreed John, I'd leave it well alone.
I went with an earlier cable throttle port injection Duratec Plus 4 as it's an altogether simpler animal that has the potential to make just as much power as the GDI, of course the real benefits of direct injection are a reduction in emissions which isn't on my priority list.
Caterham seems to have taken the same view, they also stay away from ITBs on the 360 prefering to use their own plenum on a single cable throttle body, this is my approach with Monty, I'm shooting for 185hp with my Fusion Fabrications inlet manifold and Exhaust system, increasing to a nice street friendly 210hp with Newman phase two cams.
If you're shifting a lot more air, you need to be able match it with fuel, so that's why I've gone with the EMU Black thumbs
Monty,
I've read with interest about the mods you are doing and I would agree with you that the single TB will be better for a road car, that is torque over pure BHP. You are correct in that the GDI gives good emissions but the variable valve timing also give the engine very good torque from low RPM and the BHP if you want to rev the motor. But the CS upgrade is required.
What we both probably need is a cheaper way to lower the diff gearing a tad?
Cheers
John.
