0 members (),
431
43
Posts837,277
Posts: 23 |
Hi everyone, I did introduce myself a while back ,but now I am the proud owner of a 2011 Plus 4 Supersport in sport red,will take some pictures soon when the weather improves,and attempt to post them , First question,and many to follow I suspect , I would like to replace the alternator /aux belt as a preventative maintenance measure ,and also have a spare , The handbook states the engine is a Mazda 2.0 MZR (LF) DOHC , I cannot see any identification on the belt ,all I can see is ,it has 6 ribs , If anyone can help with the belt length part number ,it would be much appreciated. Thankyou everyone Kind Regards , Colin.
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Morgan often use a different belt to the one normally used by an engine in its tin top application.
When new, the belt may well have had a length code but this had vanished from the belt on our 4/4 when the time came for replacement.
Unless an owner of the same model pops up below, your best best is to telephone Brands Hatch Morgans and order a belt. Once you have the correct belt you will have the Gates reference for future replacements.
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Paul is quite right.
Just for info the original belt numbering would be something like this (off my car).......6PK1430
6 indicates the number of ribs on the belt, so mine is a 6-rib belt. PK – The “P” indicates a metric designation and “K” indicates the belt is automotive (per SAE J1459). 1340 - is the effective length of the belt in millimeters.
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
My 2011 +4 with 2 litre Duratec has a 6PK1306 belt. I keep the spare under the seat as the original still looks perfect after 48k miles.
Posts: 2,093 Likes: 259
The TM in Talk Morgan Talk Morgan Expert
Posts: 2,093 Likes: 259 |
Congratulations Colin on your new Plus 4 SS. Regarding your belt question, I would suggest putting a separate post in the Maintenance & Service section, where hopefully one of the Plus 4 SS owners may pick up on it and be able to help. Failing that, Paul’s suggestion and SALMO’s info would be the route I’d go too. Wishing you many happy miles.
Posts: 23 |
Thankyou guys for your replies,will post in the maintenance and service section.
