7 members (ch44, RedThree, Graham, G4FUJ, B3MOG, KLASG, High Hamster, Soleng), 222 guests, and 59 robots.
+8Rich 95
Posts837,266
#777062 12/05/23 10:30 PM
Remis Offline OP
Hallo all, need some help with aero8 mk5 wiring. Maybe someone got cabin wiring diagrams? Or has some info about body control module what connects to dash switches and warning lights. (fan, heater, hazards lights, turn signal, lights, ac). That box no longer available. Should be similar in other models as plus8 or 4. Probably possible to retrofit unit from BMW models as it has canbus connection but all relays is separate. Viper switches seems bmw 1er, xenon control unit seems to be mini but not sure as also missing. Found only very simple diagram on web, most wires on dash controls same color. Don’t know why body control unit need canbus, for what function? Thanks in advance
Remis #777065 12/05/23 11:51 PM
Sorry can't help Remis but the body control module is of Volvo origin.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Remis #777070 13/05/23 06:09 AM
Sorry Remis the only electrical/electronic info published by Morgan is from their parts catalogue, download here. As you can see towards end of catalogue, just fuse info, location of modules and CANBUS topology is shown. Fitting alternate BCU would almost certainly not be possible.
Remis #778319 31/05/23 11:13 AM
Hi, I have an S5 but non of the warning lights are working. I was looking for some advice as to how to/how easy is it to get to the back of the dashboard to have a look at the pcb? Cheers Paul.
