8 members (Sir Percival, B3MOG, Jensen1960, High Hamster, Nick B, Bishmog, Rog G, Ubiquitous),
333
Topics48,348
Posts813,084
Members9,212
Posts: 1,701 Likes: 105
Posts: 1,701 Likes: 105 |
![[Linked Image]](http://www.tm-img.com/images/2023/05/15/tempImagerjjzHq.jpeg) Anybody who has a clue? After the 1500 km inspection, the oil level indicator keeps rotating, searching, and I tried everything that was suggested by the dealer, as they haven't touched the oil. It was since I bought my PlusFour from new, 6 weeks ago, always indicating 5/4! I have a MY2022 manual, one of the last MY 2022 produced. They installed an adapter for a trickle charger and an extra 12V socket apart from my USB socket (for Tripmaster etc), during this inspection. I have a feeling that it is something with the electronics, all the other functions of the bordcomputer are functioning normal. I WhatsApped them today, but I not very keen of driving a 400 km just for that......! (and there is no oil leak.....)
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 243 |
Did you try with engine running ? Mine was doing circle until I try with engine running, it take 1 or 2 minutes but at the end it give you a mesure.
Dada, Plus Six "Samantha" (the wooden witch)
I only can check it with engine running, but I can wait more than 5 minutes and nothing changes, always that circle!
Posts: 7,926 Likes: 217
Posts: 7,926 Likes: 217 |
Is there a manual check for oil level with a dipstick? If so is the level low? Our BMW B47 engined Mini has dipstick and electronic oil level checks.
Posts: 243 |
Did you push the button 30 sec, just a simple push don't work on my Plus Six
Posts: 80 Likes: 1
Posts: 80 Likes: 1 |
When you see the the spokes Ruut, as your picture shows, the manual says one or more of the conditions aren’t met. 1) It must be on level ground. 2) It must be up to temperature. 3) It must be in Park or Neutral. When working properly a glass timer will appear. When I first tried mine after buying it I had the same problem, I found that the engine wasn’t at the right temperature to trigger the sensor.
Heron Grey Plus Four 2021
Previous:- Connaught Green 4/4 1988 Black Plus 8 1998
When you see the the spokes Ruut, as your picture shows, the manual says one or more of the conditions aren’t met. 1) It must be on level ground. 2) It must be up to temperature. 3) It must be in Park or Neutral. When working properly a glass timer will appear. When I first tried mine after buying it I had the same problem, I found that the engine wasn’t at the right temperature to trigger the sensor. Hi, I fullfilled all these criteria. I already have driven 800 km with this problem, and regular checks always showed this turning circle. Last week, I promised the dealer to run the car for at least 45 min. Than I put it on a horizontal spot. Restarted the engine, and again, the turning circle. First 1500 km, until the inspection, all worked well and immediately, oil level 5/4! Either cold or hot! I ran out off options. I didn't press the switch for a long time, because I was told that was to change between km and miles!
Is there a manual check for oil level with a dipstick? If so is the level low? Our BMW B47 engined Mini has dipstick and electronic oil level checks. No, no dipstick anymore.🤷♂️🤷♂️
Did not try that because it should switch from km to miles and v.v........
Posts: 612 Likes: 13
Posts: 612 Likes: 13 |
I have the same since saturday when i pushed on the button when driving.Yesterday it was still turning. I have also since two weeks the passenger sensor in the seat not working well. If nobody is in the seat the alarm of the securitybelt is ringing.
