gomog - The nice words you say about the 1990 Morgan Plus 8 are much appreciated.
Please call me Lorne. I only use gomog because most moggers know me by that moniker.
This is my third Morgan since 1976 and is probably the best though my wife really enjoyed our original 4/4 as her working car for shopping, school deliveries, MCC Rally etc.
I have had three Plus 8s. But only two at a time. I used to leave one at home in Quebec and the other with Mike Duncan and
John Worrall in Hartlebury. I also have a wife like yours. She would haul bulbs/ blossoms and horse manure in her 1967 e-type
roadster!.
There is a reason, probably forgotten aside from oldsters for your car to be considered special. Your Plus 8s was one of the first
of the 3.9 Hotwires, (I would need a picture of the right side of the plenum and
the engine block number. to confirm. The first Hotwires were made WITHOUT cats!!! More response and power,
or so it was believed. Those who
own them have swagger rights! There were not that many made.
Your illustration is especially helpful though I am curious to learn the tool you have used to remove the cylindrical 'nut' that classed the job as 'not difficult'.
Agreed. Pictures and diagrams are always the best. I have learned that explanations, even the most pedantic ones (forgive
me) are the wisest for amateurs. It is better to bore someone than for them to get it wrong. I do not write for professionals,
though they can ...er....cock up a job as well. I write for owners.
I don't think I used a special tool to remove the threaded ring. From memory, I removed the hose clamp and hose from the tank
side first
and stuff a rag in access hole on the tank. Then I would remove the other clamp at the filler assembly. Both
hose ends might need some "convincing". These thing are decided by the man on the spot.
Now you have unfettered access to the ring. Try holding it and turning the filler cap side to unthread, There are big multipurpose
soft-jawed pliers every good fellow like you should have around.
You
may notice a watchpoint. Always put on a difficult-to-access clamp on with the release in a favorable position for next time. After the ring is unthreaded completely.the exterior part of the assembly will fall off. Check the rubber gaskets. If they are old, replace
them. I use two per filler. On re-installation lightly grease the fittings and area under the rubber washers.
I don't think I want to exclude the use of a key to open the fuel caps but I am possibly misunderstanding what you are suggesting..
No.You got it. I find a key for my caps a PITA.
As for bendable fuel filler hose.. google that and buy a length to fit both sides with the right ID. If you can't find one, tell me.
Lorne
