Topics48,345
Posts813,037
Posts: 1,011 Likes: 243
Posts: 1,011 Likes: 243 |
In Italy it rained only once today... sometimes more, sometimes less. After about an hour of driving in the rain, water came out of the dashboard. Has anyone ever had this before? If so, how can it be fixed? ![[Linked Image]](https://tm-img.com/images/2023/05/16/240d7955-49bd-4880-9929-11d777a24245-1.jpeg)
Clemens
PlusFour Red Baron MY 2022
Posts: 7,922 Likes: 217
Posts: 7,922 Likes: 217 |
Typically if it's not dripping from top of windscreen onto dash it must be coming in from poor seal on lower part of screen. A bulkhead leak would have water ingress behind dash. You should be able to simulate with a hosepipe playing onto screen and hood whilst someone with tissue checks internally.
Posts: 11,221 Likes: 159
Posts: 11,221 Likes: 159 |
This is an improvement on previous models. https://youtu.be/ZFvd9DVt9-I?t=113(On the older cars it came in around the windscreen seal and also on the leading edge of the drivers door but looking at yours I would say the windscreen?
Posts: 612 Likes: 13
Posts: 612 Likes: 13 |
Never at that place ,only on the top sides of the windscreen when rainning intensively. Check the seal at the base of the windscreen , it could be twisted when the windsreen was mounted.
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
Take itr back if under warranty. Water & pcbs etc don't mix. It could also be leaking screen wash pipes on my roadster the T piece had a crack..
Posts: 2,792 Likes: 161
Posts: 2,792 Likes: 161 |
Some washer bottle additives can congeal over time if not regularly used, you normally see it in the washer bottle which get sucked up into the plastic piping, blocks and under pressure when using the washers to clean the front screen forces the pipe off the plastic T junction and drips inside the cabin behind the dashboard usually onto the transmission tunnel. If it is the case easy fix, but use tie grips on the plastic pipe ends to stop it happening again.
Prev '12 Plus 4 Sport OZZY '08 Roadster FELIX '06 4/4 70th LOKI '77 4/4 SEAMUS '85 4/4 MOLLY
Posts: 7,895 Likes: 241
Posts: 7,895 Likes: 241 |
Check the seals around the 3 wiper spindles where they enter the scuttle bodywork
Thanks for all who help me here. Today was even heavier rain than yesterday and no water penetrated through the dashboard. On the one hand, that's good, on the other hand, a non-reproducible error is very difficult to fix.
Clemens
Posts: 3,425 Likes: 26
Posts: 3,425 Likes: 26 |
Drip some Captain Tolleys sealer around the spindles and the washer spigots - if there is a leak there, this will solve it - I suspect though that it is the windscreen seal that is the problem and in a new car, the dealer should fix it, and promptly!!!!
Posts: 468 Likes: 52
Posts: 468 Likes: 52 |
Our Plus Six showed a small leak and that was traced to the washer jet area, however, that dripped much lower down under the dash.
