2 members (yobtaf, BHV),
276
40
Topics49,860
Posts837,486
Posts: 1,647 |
If its off the road for a while or not off the road the cold weather will bugger up your rear window and it will discolour and can crack in future . Best to keep hood up over winter . Good point ! Also, when the car is 'inside' over the winter or long periods, I put the roof on the frames but don't fasten it down fully so the hood is not under any tension. If your hood frame has swivel pivots it will be even easier for you to take the tension out of the hood when the car is tucked up in the garage.
Jaguar F-Type V6s roadster 2009 Harley Davidson XR1200 1986 Honda VFR750F (RC24)
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Swivel pivots are a godsend for Everflex hoods. Mine is on permanently in winter but only used in a downpour. It can be folded fairly tidily when down but put up when garaged to hold the shape. Phil at Allon Whites advised beeswax on the seams to maintain wtarproof level.
Posts: 14,009 |
My dealer is not too keen on the swivels...he thinks the over centre action can put too much pressure on the top rail leading to risk of screen fractures. He was watching me put up my hood and reckoned the top of the screen moved back a 1/4 inch or so!
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Mark at the factory told me it is best to fasten the front with the rear studs not fastened and then fasten the rear studs.
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
That's the only way I can fit mine!
I have a pair of hood swivels to fit, but they are designed for the newer cars which had a longer mounting bracket. I think I will have to remove some foam from the bench seat backrest to accomodate the ball end of the swivels too, otherwise there may be excessive sideways force trying to pull the bracket from the car body.
Cheers,
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
THERE IS A CERTAIN WAY TO FOLD AN EVERFLEX HOOD SO THE REAR WINDOWS ARE NEVER FOLDED , ASK ABOUT THE LADS WHO HAVE THEM IN THE REAR MAY KNOW THEN  TELL YOU OR SHOW YOU
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Posts: 14,009 |
The Everflex hood folds up easy enough to avoid creasing the windows...one advantage it has in being fully dismountable from the car!
Is the rear window in the Easy Up hood made of a different material? I assume that it folds in half when the hood is stored.
Posts: 318 |
Hi - The hood is the factory fit easy up and the previous post was right it folds neatly inc the window if done correctly so i will leave as is and report back in the summer - well april anyway -Thanks for all the info
2013 Plus 8 Aero S5 Build week 11
