10 members (MJF, GrandadC, Oskar, B3MOG, JohnHarris, t50, +8Rich, DJC, High Hamster, david nathan),
312
Topics48,335
Posts812,889
Members9,203
Posts: 1,011 Likes: 243
Posts: 1,011 Likes: 243 |
35 kg on a luggage rack is considerable although maybe 40 kg with side screens  . I believe I've seen published a recommended 25 kg capacity on the trad luggage racks. Having said that the rear mounts did look flimsy and would ideally require some form of re-engineering, warranty concerns aside. Of course, I'm also thinking about a weight restriction now after this incident. Thank you Richard for this hint. Where can I find this information ?
Clemens
PlusFour Red Baron MY 2022
Posts: 2,380 Likes: 56
Posts: 2,380 Likes: 56 |
Morgan often have faults in their engineering but to be fair that rack was never meant to take nearly 90lbs in weight...
Posts: 7,916 Likes: 216
Posts: 7,916 Likes: 216 |
35 kg on a luggage rack is considerable although maybe 40 kg with side screens  . I believe I've seen published a recommended 25 kg capacity on the trad luggage racks. Having said that the rear mounts did look flimsy and would ideally require some form of re-engineering, warranty concerns aside. Of course, I'm also thinking about a weight restriction now after this incident. Thank you Richard for this hint. Where can I find this information ? Sorry Clemens I cannot find the MMC published info now and as I said related to trad cars. When I did see it I was prompted to weight  's humungous suitcase which came out at 23 Kg packed to the brim. TBH that's almost as much as I can lift nowadays  Touring with this weight, spare wheel plus full tank (52 litres = 37 Kg) is ok thanks to the dual rate SSL coil spring rear but suspect bumps at speed with leaf springs would have them bottoming out. No idea of CX cars but hopefully they have adequate reserves of suspension travel and of course smaller tank capacity.
Posts: 6,055 Likes: 159
Posts: 6,055 Likes: 159 |
Agreed - that is a lot of weight. To put in perspective, the old Landrover Defender roofrack only had a recommend limit of 75kg!
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
I have only estimated the weight of the suitcase. The first thing I will do when we are back in Germany next week is to put the suitcase on a scale to find out the exact weight.
Clemens
Posts: 1,699 Likes: 105
Posts: 1,699 Likes: 105 |
Hi Clemens, let's start to say that I hope you enjoy the rest of your holiday. I think you were very well prepared with the bespoke luggage on the rear shelf and the thoughts about the suitcase. So there is nothing to blame you. Maybe the 2 sidescreens extra on the suitcase became too much!? Still, should not happen. I know you have the luggage carrier without the sidescreen-spare option, so you was not planning to put them on the rack too!? As our Morgans are nearly as old (or new) and I have the same rack, we stick to a smaller leather suitcase with mohair enveloppe, and put as much as we can in the bags behind the seats while traveling to Denmark. And leave a lot at home....! SWMO Bianchi doesn't like driving the Morgan without widescreens, so that was never an option. And if it becomes too hot in Denmark  we can always close the hood and switch the aircon on! I'm very interested what MMC has to say about this and if this ever happened before. And they have to fix your damage. I'll watch your posts closely! Regards, Ruut
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Hello Ruut, I bought the luggage bridge with side screen bag especially for this trip. But the torque becomes even greater with this bridge. You can see it quite well in the picture. I also have to praise my dealer very much. A new bracket will be delivered in two weeks and extra welded. My dealer also thinks that the welding of the bracket is not very well done. ![[Linked Image]](https://tm-img.com/images/2023/05/24/FullSizeRender.jpeg)
Clemens
Back to the topic of this thread ... nice ride from Lago D'Iseo to Bolzano ![[Linked Image]](https://tm-img.com/images/2023/05/25/IMG_1468.jpeg)
Clemens
Posts: 612 Likes: 13
Posts: 612 Likes: 13 |
nice view . I wonder why they have removed the stop lights in the hood and going back to the horrible periscope.
Posts: 2,062 Likes: 57
Posts: 2,062 Likes: 57 |
nice view . I wonder why they have removed the stop lights in the hood and going back to the horrible periscope. As always: Money??
