Morgan Aero 8
2 members (RichardV6, TeddyAds), 295 guests, and 96 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,615
Moggo
Formerly known as Aldermog
Originally Posted by hashluck
Originally Posted by PJC
I have also heard that the Fan Control Modules can cause unusual issues with heating and cooling. You may also find that having had the system re-gassed and pressurised that an O ring seal is leaking slightly under the increased pressure. Most A/C systems need running regularly to use the gasses to lubricate the pipes and O rings etc.
My seals went due to lack of use by the previous owner. I run the AC all the time..
I do in the other cars...perhaps I should in the Morgan.
I rarely run the AC in the Morgan - it seems rather pointless as I only drive it in fair weather. I know you should run AC all the time to keep it healthy.
+8 4.8
Exactly.
Jdm Offline
Anyone/everyone,
The heater fan on my aero S1 has started to play up, in as much that it is always on when the ignition is on, and won’t reduce in speed or turn off. I suspect that the heater blower fan resister (which controls the current to the heater fan) may have failed. Does anyone have any relevant experience, like where the resister is located, or from where Morgan sourced the part? Just at the moment, the factory/dealers seem not to have the relevant parts or knowledge.
All knowledge/input gratefully received.
Thanks
Jdm
Jdm, Your gonna have some problem's afraid to say regarding parts.Just on the off chance under the steering column there is a six or eight pin connector well known for giving air con issues this tends to carrode and gum up well worth a go.
Sir S1'a'lot
Sir S1'a'lot
My S1 has just developed a problem.
It’s an electrical issue. But no idea why or what. It’s gassed and fan works
Any ideas?
2002 Aero 8 S1
2023 Plus 4 (woman’s)
If you think it might be a switch issue remove the plasic panel under the dash their short small stubby screws once removed you will see a large number of wires about an inch thick cable tied either side of the air con rotating knob, cut both cable ties and move the loom to one side and you can gain access to the two switches. I did this to mine and also found out why the heated screen stopped working. It was a water ingress problem from the windscreen washer pipe. That's another story flippin nightmare......
