5 members (John Winn, TeddyAds, Martin W, Julian BB, Pigiron), 350 guests, and 31 robots.
+8Rich 92
Topics49,839
Posts837,298
Page 7 of 7 1 2 3 4 5 6 7
Rog Offline
Originally Posted by Deejay
So, yes, either a sticky king pin or sticky shocker. But, I don’t notice any ill effects on the road.
Has anyone else noticed the front suspension skip/stiffen on hard fast cornering? I guess it’s the increased pin to bush frictional drag from the imposed side loading.
Roger
CBY Offline
Has anyone tried a dose of 'moly' based grease to reduce the kingpin sticktion ?
I use MOLYKOTE br2 plus. We used it on board cranes, ships and other equipments when I worked in engineering.
https://www.lubricantspecialty.com/...lykote-br-2-plus-high-performance-grease
Regards
2005 PLUS 4
Originally Posted by rainbowj
I had to ask for the C spanners and was given no instructions. When I got home I phoned up about the instructions and was told they were on the Web. They are not. E mail to SSL and instructions sent as attachment to returned mail. SSL said that a laminated copy of the instructions are provided with each kit!
I have set up the suspension using the spanners, the near side is spot on but the offside keeps varying. Can only think that I have a sticky king pin. New King's pins fitted with suspension.
Yes I dropped on a trolley jack a few times.
This can be tricky but as I said earlier a median can be found, important that kingpins freshly greased though. If there is a gap try lifting that side very gently under kingpin then leaving go. If the gap has closed you're nearly there, if not screw down collar a tad more.
Yes yesterday but it was a washboard surface that caused it I believe and certainly not the norm.
Wolf performance sell this grease now. Image link.
Cannot comment on performance as not yet tried.
Rog Offline
The next step after lubrication for reducing stiction/fiction is a material change. The friction coefficient will be roughly halved when using super slippery Vesconite Hilube bushes.
Made these for my previous car but never fitted them. Patiently waiting for the bushes to wear on my current car… waiting
With Mulfab hard chrome pins
Roger
