13 members (John V6, JD44, +8Rich, TomS, DMC1904, Grumpy2, MDS61, MJF, The Flitting, asterix, BLUE+4, mph, John07), 302 guests, and 44 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,336
Members9,215
Page 8 of 9 1 2 3 4 5 6 7 8 9
nick w #779773 20/06/23 11:30 AM
TBM Offline OP
Originally Posted by nick w
32 mpg is very impressive
Yeah, I was hoping for high '20's' so very happy with that. Good tune, and sensible/smooth driving. I do 50 miles a day, but most is 50-70mph roads so I can maintain a comfortable cruising speed in overdrive.
TBM #779793 20/06/23 05:16 PM
Originally Posted by TBM
, rather than the 'SAGA Holidays' brochure we get from MSCC.
Made me giggle laugh2 laugh2 (with the exception of DW's page)
TBM #779811 20/06/23 08:20 PM
32mpg is indeed very good, I used to get around 28mpg. 1800 or 3500cc were roughly the same. the K&Ns will make it a tad lean so check the plugs
TBM #782815 03/08/23 05:21 PM
TBM Offline OP
As I've got a few weeks off, it's been all hands to the pumps on the MG..
Been a little tricky with the rather inclement weather, but I've had a couple of dry days. First priority with any car is to sort out the brakes and handling, so have fitted new calipers, braided hose, drilled and slotted discs and EBC green pads. It is supposed to be a '25%' improvement, but anything will be better than the tired stuff that was on there.
Then a pair of uprated and lower front springs - the rubber bumper cars were raised due to US regulations so this will bring it down a couple of inches and firm up the cornering.
Cracked on with the back end today to fit a pair of lowering blocks, but discovered that one of the rear brake cylinders was leaking so ordered a complete overhaul set - silly prices again -new drums, shoes, pistons, adjusters and all the associated springs for under £120 inc delivery
Noticed the rear springs were looking a bit knackered - one was starting to spread and one of the leaf clamps had split. Whipped them off and gave the credit card another mild bashing - new springs, bolts, U bolts, pads and rear shackles for £135 inc delivery. Couple of dry days next week so wait for the postie and start bolting it all back up.
Also got a couple of new seat bases to fit to stop the sagging.
Poor Mog is feeling a bit neglected, but the weather is looking better next week, and I did manage a breakfast at the MMC Experience Centre last Friday....
TBM #782825 03/08/23 08:08 PM
Loving the parts prices.
Looking forward to the reports on how much better the car goes.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
TBM #783155 08/08/23 05:30 PM
TBM Offline OP
Everything all bolted back, although I'm absolutely knackered!
Brakes are still a bit soggy, but with four complete new sets it's going to take a few miles to get everything bedded in. Will get a couple of hundred miles under the belt and then check everything over and get the rears agjusted up properly. Also need the suspension to settle a bit but already an inch or so lower.
Seats are a massive improvement - really comfy, fitted some neoprene sheet between the seat foam and the new webbing (like I did on the Mog) to help spread the load.
TBM #783194 09/08/23 08:56 AM
The brake pedal on my 1980 with twin circuits was always long pedal and soft, even with only 5,000 miles on. Seems to be a function of the twin master cylinder.
Whereas my 1974 with single circuit and remote servo had minimal travel and was much harder, and much more as I like it.
DaveW #783200 09/08/23 10:19 AM
TBM Offline OP
That's a perfect description of what I have, and gives me some encouragement, thank you.
I don't really like it, but will probably get used to it. Just been for a 15 mile spin round the block and already have more confidence in the system. If I can't get used to it, I'll ditch the servo and revert back to a simpler system. Over on the MG forum a few have told me that 'it's a classic car and you can't compare it to a modern vehicle'. I'm not - I'm comparing it to a 1972 Morgan that has proper brakes....
TBM #783203 09/08/23 10:35 AM
If you revert to the earlier single line system with remote servo it will feel a lot better. In fact it shouldn't make too much difference to not have a servo.
I tried for 22 years to get a harder pedal with the dual system, and nothing made any difference.
Pump the pedal with the engine off, and the pedal will come up. Start the engine with your foot still on the pedal, and it will sink again.
DaveW #783232 09/08/23 02:54 PM
TBM Offline OP
Yep, exactly that. At least I'll stop chasing my tail trying to achieve the impossible with the standard set up. Cheers.
