8 members (Strathaven, MartinB60, SteveT, Hamwich, tezzer, Graham, G4FUJ, TeddyAds, BLUE+4), 336 guests, and 86 robots.
Topics49,848
Posts837,399
DazMog, The Impaler, tlchzj79
The world's greatest endurance race is now 100 years old.
To celebrate, Monty enjoyed another dash through the glorious French countryside to attend the 2023 Le Mans Classic with over 800 historic competition cars, 8,500 classic cars on display, and 235,000 spectators.
This was our second pilgrimage in the 12 months I've owned the car, but this time the subtly backdated Monty handled perfectly, sounded epic... and went like a stabbed rat Devil6
The fully enhanced Monty is now an absolute weapon and the French seemed to fall in love with him wherever he went love
Good news all went well. Has the lightweight flywheel been fitted yet?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Not yet Doug.
Next up are the Newman Phase two cams for another 30hp.
* Power Band: 2500-7250
* Duration: Inlet - 275 Exhaust - 275
* Valve Lift: Inlet - 9.52mm Exhaust - 9.52mm
After that comes the Titan 3.2 KG steel flywheel.
And the Stage 1 organic clutch kit for the Mk3 Mazda MX5 (NC variant) from Exedy in Japan who are well renown as one of the worlds leading manufacturers of quality clutches and are the OEM suppler to Mazda themselves.
The organic disc features a newly developed asbestos free friction facing, which has high heat resistance and high burst strength characteristics. No steel back is required which can cause high RPM "lock out" and/or synchro damage.
Exedy Ratings lbs/ft:
Clutch Torque: 298
Torque @ flywheel: 238
Torque @ wheels: 191
This complete kit is ideally suited for either stock or modified Duratecs, the drivability characteristics of the organic material disc are similar to the stock clutch. Increased pressure plate clamping loads provide the necessary capacity to handle the performance demands of modified engines and spirited driving and while pedal loads will be slightly higher because of the increased clamping load, this kit is well suited for use on daily-driven cars.
This clutch also gives a 10% reduction in inertia over OEM so combined with the Titan 3.2 kg flywheel Monty's Dureatec will get up on the Newman Phase 2 cams much quicker.
The target is a nice street friendly but fully weaponised 200 - 210hp Monty with good mid range torque characteristics largely helped by the excellent FF inlet manifold, but also with the capacity to wind out to 7,250rpm for that screaming banshee effect.
drive
From Aston Martin
To Morgan
They said I was mad
But I have no regrets....
thumbs
David
MY22 Plus Four, Alligator (AML Racing) Green ! 😍
