1 members (JoeSpeetjens),
328
38
Posts837,276
Posts: 564 Likes: 79
Posts: 564 Likes: 79 |
Hi Clemens, the weld to your luggage rack fixing point is exactly as I propose to do on our Plus Six.. I may have to put the weld off for a while as we have just returned from a week in Brittany with the Plus Six and now have a list of issues to be addressed with the car including another radiator water leak and coolant loss.. I hope its not the rad as this was replaced due to a leak several months ago.. Its hard to keep the faith with these cars when you experience so many issues.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
I have to give a big thumbs up about my dealer here. The support and communication is fantastic. Picked up my PlusFour from the repair today and everything was put in order without any problems. My broken bracket and the luggage rack was replaced and the bracket additionally welded. The paint damage is no longer visible. A few other little things were taken care of as well. Have the bracket additionally welded and then the weight is no longer a problem. The orginal bracket is in my opinion a misconstruction. ![[Linked Image]](https://tm-img.com/images/2023/07/01/8ec65f92-565b-470c-88c9-008bce2446f9.jpeg) Looks much more secure
Posts: 148 Likes: 11
Posts: 148 Likes: 11 |
Hi Clemens,
Can you please tell me what was the weight of the bag that was on your rack when it broke?
Also did your dealer give you any guidance as to the weight the new bracket will carry?
I look forward to hearing from you.
Best wishes,
John R Marchant Plus Four JT10MOG "Florence"
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Hi John, The suitcase transported on the broken bracket weighed 31 kg. I have not received any information about a maximum weight on the additionally welded bracket. This is now my risk. But I trust the holder now a much higher weight when I look at the previously let's say better spot-welded bracket.
Clemens
PlusFour Red Baron MY 2022
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
Hi John, The suitcase transported on the broken bracket weighed 31 kg. I have not received any information about a maximum weight on the additionally welded bracket. This is now my risk. But I trust the holder now a much higher weight when I look at the previously let's say better spot-welded bracket. Glad to hear all is settled well Clemens. I will have my PlusFour checked when am at the dealer.If it is spot welded they did promise me to have it double SS welded.
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
This is how the original bracket looks like Ruut ☝️ ![[Linked Image]](https://tm-img.com/images/2023/07/04/IMG_1903.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/07/04/IMG_1902.jpeg)
Clemens
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
That looks as if it’s retrofittable to a chassis , although we were told it could only be fitted at manufacturing. Has the chassis / bracket been re- engineered??
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
That looks like a simple spot weld. Simply not up to the job! Such a small area of weld is never going to last with stresses of load and vibration. The extra welding is a must. It looks like a beancounter’s spec rather than an engineer’s spec. When I worked in a car rad factory we spot welded the tank pipes ( brass tanks) then they were high temp soldered sealing the pipe/tank joint. The spit weld was done in a jig for correct orientation and added some strength. Why high temp solder? Assembling a rad meant using a jig to position the tank on the core tube p,ate. Normal temperature solder was then used to fix and seal the tank to the core.the pipe solder wouldn’t melt at this stage, maintaining integrity. If QA started ( correctly at the design stage as it should) then that assembly would likely be declined for a better one. What effect on reputation versus marginal better quality built in cost? An example of excessive cost cutting? On second viewing is that lug pushed through a hole in the base and then welded normally? Better than a spot weld but only just. Still not the best option though.
This is how the original bracket looks like Ruut ☝️ ![[Linked Image]](https://tm-img.com/images/2023/07/04/IMG_1903.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/07/04/IMG_1902.jpeg) Thanks for the images Clemens. The coming weeks I'm not planning to undertake large trips with the Morgan, but I do have some spare time during holidays, so now I am much more determined to show my PlusFour to the dealer for inspection, they already promised to weld it if necessary, but a trip to the dealer is 400 km for me (retour) so I have to plan that on a weekday when I am free and they are able to inspect it. I now have the feeling that there is a fair chance it's only spot welded, so that means I will have to leave here there and pick her up on another day! Retirement is only in December.........
Ruut, taking another look I think that looks more and more like a lug pushed through a hole in the base part and then welded at the rear end to hold it. Looking from the front there appears to be a gap where the parts meet indicating a hole/slot that receives the other part. The weld at the back looks like a Mig/Tig weld rather than a spot weld. You can see the “puddle” effect where the filler wire was welded in. It would be difficult to spot weld due to the shape and thickness.
