2 members (Brian G, Jo S), 260 guests, and 32 robots.
John V6 69
DaveW 68
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,023
RedThree
If you're careful about where you drill the holes for the rivnuts, you should be drilling through two layers of aluminium which provides for a solid mounting. I also used 3mm self-adhesive neoprene on the back of the rectifier to protect the paintwork.
Andy
Originally Posted by Bitsobrits
"Did you make a mounting/backing plate to be located behind the body panel inside the footwell forward of the pedal assembly?"
I used a fabricated nut plate on the inside for my install, but I like Bunny's rivnut idea as well.
Thank you Steve and Bunny for the info I will probably relocate it. I have the HD Rectifier installed and made darn sure it was grounded thoroughly.
Good suggestions guys.
