6 members (sewin, hugo, Bishmog, Rog G, Sloany, DaveK), 287 guests, and 39 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,363
Posts813,333
Members9,215
#781927 21/07/23 08:46 PM
HKNYMOG Offline OP
Running the 3-wheeler the other day noticed voltage on the readout at 17.1. Normally at 14.1 ish... Any thoughts? Yet another regulator biting the dust??
2013 M3W
2019 Roadster
You should normally be seeing more like 14.4 volts when running at more than about 1,500 rpm. at 17.1 you are in danger of overcharging/overheating the battery and, more importantly cooking your ECU.
Unfortunately it does all point to the regulator and a well proven replacement is detailed in the Alternative Parts List.
Red Leader drive
HKNYMOG Offline OP
Chris thx.. Another regulator bites the dust.
2013 M3W
2019 Roadster
If your regulator is still mounted on the engine mount, I would suggest relocating to the body somewhere. In this photo you can see where I relocated mine. Look just below the left turn signal.
In this position it gets direct cooling air when viewed straight on.
Late 2012 M3W
Yes get that sorted quickly as it will impair life of battery due to extra acidity in electrolyte from overcharging. ECU damage is unpredictable but certainly possible.
The regulator the Harley type can be reliably mounted in the same place as the OEM. You can also mount it directly to the backplate, no need for the rubber isolator blocks.
If you replace with an OEM Morgan regulator then moving the mount to the later car's side of the engine location is a good idea.
Red Leader drive
Did you make a mounting/backing plate to be located behind the body panel inside the footwell forward of the pedal assembly?
It is a cleaner location for the rectifier for sure.
Also check the earth connections are good and clean and more importantly a metal to metal contact (Morgan seem to think a shakeproof washer makes a good earth connection without removing any paint), i have had similar regulator problem with a bad earths on a classic car purely down to a bad earth
If anyone wants to relocate their Rectifier, this may help.
Andy
1 member likes this: Will Stotts
"Did you make a mounting/backing plate to be located behind the body panel inside the footwell forward of the pedal assembly?"
I used a fabricated nut plate on the inside for my install, but I like Bunny's rivnut idea as well.
Late 2012 M3W
