Posts837,279
Posts: 651 Likes: 12
Posts: 651 Likes: 12 |
Are the fuel lines in a Duratec Plus 4 resistant to ethanol? I soon discovered that the rubber tubes for the windscreen washer fluid was not, and now I am concerned because the standard gasoline has become E10.
Harald
Harald +4 4-seater 2008 Squadron Blue
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Cars built from 2002 onwards should be OK with E10.
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
There was a discussion on here some time ago when E10 was introduced. I thought that things like the tank filler pipe may not be guaranteed to be resistant and if I recall, there wasn’t any real definitive advice from MMC. I will need to look it up again.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
That is correct Doug. The bits that are Mog specifiic might be at risk, but so far I haven't heard of issues
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Hararld, your Ford engine is ok, but safest to consider anything flexible fitted by MMC may not be compliant unless the actual hose is printed DIN 73379. SAE J30R9
