5 members (Hamwich, gaston, Ian Wegg, Fuel.inj, Morganmike), 388 guests, and 55 robots.
+8Rich 92
Topics49,838
Posts837,293
#781885 21/07/23 12:14 PM
Soleng Offline OP
Are the fuel lines in a Duratec Plus 4 resistant to ethanol? I soon discovered that the rubber tubes for the windscreen washer fluid was not, and now I am concerned because the standard gasoline has become E10.
Harald
Harald
Cars built from 2002 onwards should be OK with E10.
There was a discussion on here some time ago when E10 was introduced. I thought that things like the tank filler pipe may not be guaranteed to be resistant and if I recall, there wasn’t any real definitive advice from MMC. I will need to look it up again.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
That is correct Doug. The bits that are Mog specifiic might be at risk, but so far I haven't heard of issues
Hararld, your Ford engine is ok, but safest to consider anything flexible fitted by MMC may not be compliant unless the actual hose is printed DIN 73379. SAE J30R9
