6 members (Clipper, Ady42, +8Rich, Tresco, JMcL, Joske Vermeule), 323 guests, and 113 robots.
+8Rich 75
Topics49,869
Posts837,660
Moggo
Originally Posted by asbojohn
I'd give Cain at Wolf Performance a call , with the GDI engines in the racing club sports we've had a number of diffciult to find issues the most common is the the throttle bodies.
He should be able to give you some help in identifying the problem.
Met Cain yesterday and he mentioned about sticking throttle bodies on GDI engines. I can confirm the OBD Torque Pro app working with ELM327 bluetooth dongle will display both pedal and throttle position and would therefore show any issue there.
Worth noting that my Roadster which runs fine, displays max 80% for pedal position with corresponding ECU limited max of 75% on throttle. Apparently this is not unusual as the extra makes little difference.
Originally Posted by DaveW
Originally Posted by Tim Crump
Dave
Interesting, I spoke to Brett @ BHM this morning, he was mistified as the only problem they usually have is the key not communicating - something I know you have written extensivly about.
But as inserting the key stops the flashing light that doesnt seem to be the problem.
However I'm not sure about the immobiliser, the flashing light goes out when I insert the key - tick
But if I leave the key in it stays out, whereas I'm sure that after about 20secs it is supposed to start flashing again
As I recall, the immobiliser light has a different flash sequence if you leave the key in but don't start the engine.
Try leaving the battery disconnected overnight, and also make sure it's fully charged, there may be a voltage sensitive issue going on.
I'm with Dave on the ECU seeing low volts, especially if you've been cranking a 'dead engine' several times
Tim earlier this year I posted on my GDi engine not starting,I had a spark but no wet plugs,immobilizer ok,so I took the air intake tube of the back of the engine,and squirted easy start in ( dont like doing it but needs must) and it started ,and has been fine ever since,worth trying,with fully charged battery. duncan
duncan series 1 climax, TR +4, plus 4 GDI
SSL F&R suspension
Duncan
Thanks for the Easy Start suggestion. Dont have a can on the shelf so will get one.
Away now for a week so nothing will happen meantime.
Tim
Plus 4 2018
In an emergency the aerosol brake cleaner stuff is as good as Easy Start
👍 Almost all motorcycle riders do this
Clemens
PlusFour Red Baron MY 2022
Hi Tim
I had a similar problem on my 2014 +4 GDI last year.
I did all the usual checks - fuel pump running then shut off, sparks OK, engine breathing OK - then gave up and had the car recovered to Tim Ayres at New Elms. They did further checks on sensors etc - all OK.
The final diagnosis was that the fuel pump was running but not delivering sufficient pressure.
New fuel pump fitted - all OK
2014 +4, Le Mans Blue / Magnolia
"Meg" the Mog
Back in 2018 my GDI would not start - I found the cylinder head of GDI has a secondary earthing wire fixed to the rear of the head low down just above the join with the main block on the left hand side (passenger side in UK). Photo from the rear left hand side of engine shows the wire (pinky red, running vertically upward) bolted via a ring connector to the head. Not a good photo but best I could get as access is poor and flash bounces off all sorts.
When my GDI would not start (engine turned, petrol pump worked etc) this bolt was found slightly loose – when tightened to ensure good earth for cylinder head all was well.
+4 GDI Connaught Green, 2014
Magnolia
So after trying various ideas and suggestions from TM members I had a chat with Len at BHM over the phone when he listened to the engine turning over he thought it a little slow.
Len's suggestion was to try a jump start in case the battery was not providing enough oomph.
Tried this and although it didnt work straight away she eventuarry did start.
Generally I do runs of over 30 mins at least 4 times a week so the battery gets plenty of chanrging, but maybe this was disguising its true condition.
Anyway now it's time to find a replacement for the original Banner Uni Bull 50 200 which they no longer make (sems like it might be a banner power bull p60 09
Tim
Plus 4 2018
Once you put the new battery in it might be worth checking that the alternator is cranking out the correct amount of juice.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
