5 members (TalkMorgan, BobtheTrain, Bishmog, Graham, G4FUJ, Adam12), 308 guests, and 48 robots.
+8Rich 63
Adam12 61
John V6 55
9,215 Registered Users
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
Wet Brakes
by IcePack - 27/07/25 03:34 PM
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,361
Posts813,298
Members9,215
AndyR, AxelBorg, Herbert
Page 3 of 6 1 2 3 4 5 6
Being a bit of a Luddite, my solution to spinners has always been a big (2.5 lb) rubber mallet, which I keep on the floor behind the drivers' seat.
As they would say in these parts . . . ."proper job"
cheers
Bud
4/4 "Stanley"
Green & Grown Up
Green & Grown Up
Originally Posted By Budster
Being a bit of a Luddite, my solution to spinners has always been a big (2.5 lb) rubber mallet, which I keep on the floor behind the drivers' seat.As they would say in these parts . . . ."proper job" cheers
I also have the MG Tool & Leather protector finger. (winter job is to fine grind the pressure edges to be 'rounded'). It works a treat, if a bit on the large side.
I suppose if one is concerned about the weight of it, then an afternoon with a large drill bit could reduce it a little and make it look more sporty at the same time idea
As a wearer of Varifocals, it is a bit like that old 'Bi Focals' Golfing Joke, when bent over I see a big spinner and a little spinner. Which one would I have to give that 'Big Clout' with the old 'Mallet'? grin2
Method I a 2kg leadhammer.
Method II a steel tool.
Method III a homemade wooden tool ( perfect )
Cheers Rudy.
Green & Grown Up
Green & Grown Up
Hi Rudy,
A Great set of photos.
Problem with the Roadster is the deeper set spinners on those wide wheels. It is easy to hit the rims when going for the spinner with a mallet. The MG tool compensates for the offset nicely. Middle image.
The best tools for removing spinners are from Oldtimertools:
http://www.oldtimertools.de/en_index.html
Greetings Jens
2003 Morgan 4/4 2-seater
Jens #78328 07/01/12 12:56 PM
Greetings Jens
That looks excellent; plus as an "oldtimer" I love the name of the company.
oldgit oldgit
Bud
4/4 "Stanley"
Rudy, do you really have all three types of spinner on your car? innocent
V
V
When I purchased the box of parts from which I renovated my 1935 MG PA it came with a tool! which was ideal for removing the two eared spinners which are exactly as those on my 4/4 Sport.
It is a piece of laminated wood about 1" thick, propeller shaped 20" long in the centre of which is a hole cut through the same shape and size of the spinner. This can be placed over the spinner and hand pressure is almost adequate to tighten or loosen, with the addition of a tap from a copper mallet. It can be reversed to use on the opposite side. No damage is done to the spinner.
_____________
Jack
Now THAT is a good idea!
John Rutherford (1988 +8)
Those are readily available from the likes of Heart of England etc. Got mine from there and its made by MWS, makers of the Morgan wheels.
