8 members (mph, A11OGE, CLPlusFour, MJF, High Hamster, Arwyn Williams, RedThree, MartinB60),
314
42
Topics48,362
Posts813,321
Members9,215
Posts: 7 |
Hello, I'm Gerard I'm desperate, I don't have a Morgan workshop here in Spain Normal workshops could not help. My morgan: morgan plus four, built in 1992, Motor Rover m16 17000 miles Problem: it starts great, runs smoothly and powerfully After about 5 miles the power drops and at full throttle there is no more combustion Gas back and forward again, but he jerks no more. The ignition off and on briefly and he drives about 5 miles normally again. This keeps repeating itself. I have already done that: Engine control unit ECU replaced (error remains the same) Tank cap left open (pressure equalization) New fuel pump and fuel filter candles new Checked water and intake manifold sensors The phenomenon is the reset by ignition off/on Maybe someone has ever had such a mistake, I would be grateful for tips. Many greetings, Gerhard
Posts: 1,961 Likes: 43
Posts: 1,961 Likes: 43 |
Poor contacts in ignition switch possibly?
Posts: 7,940 Likes: 218
Posts: 7,940 Likes: 218 |
A long shot unless someone knows different but try a new fuel pump relay.
Another possibility is blockage somewhere in fuel line that eases when no fuel pressure.
Posts: 2,255 Likes: 2
Posts: 2,255 Likes: 2 |
when I had an M16 Plus 4 , which was usually reliable, I had just two issues, One was similar to yours in that power fell away but on restart was normal. This turned out to be a failing alternator. We did think of that first but dismissed the idea. However after eventually changing it there were no more issues of that nature. The other occasion was an abrupt engine failure as if the ignition hd been turned off. That was the clue of course. A quick swap over of the two relays under the dash by the bulkhead and the car started and ran as normal. I guess we are clutching at straws here but this might be helpful.
Posts: 7 |
Poor contacts in ignition switch possibly? aber immer nach etwa 5 Miles , auch während der Fahrt .aus/an läuft er gleich weiter
Posts: 7 |
Another possibility is blockage somewhere in fuel line that eases when no fuel pressure. danke für die Info ich habe die Pumpe extra geschaltet und bei Motor ruckelt aus und eingeschaltet.keine funktion.nur mit zündung aus/an verrückt!
Posts: 7 |
when I had an M16 Plus 4 , which was usually reliable, I had just two issues, One was similar to yours in that power fell away but on restart was normal. This turned out to be a failing alternator. We did think of that first but dismissed the idea. However after eventually changing it there were no more issues of that nature. The other occasion was an abrupt engine failure as if the ignition hd been turned off. That was the clue of course. A quick swap over of the two relays under the dash by the bulkhead and the car started and ran as normal. I guess we are clutching at straws here but this might be helpful. tnx ich werde die Lichtmaschine überprüfen lassen allerdings ist das Bordnetz immer bei 13 bis 13.5V das bedeutet,die Lichtmaschine funktioniert. oder ?
Another idea to determine whether it is an electrical or a fuel problem. How long does it take you to drive 5 miles? Start the car, but do not drive it, just let the engine idle for the same amount of time that it takes to drive 5 miles. If it still cuts out, then it is unlikely to be fuel related but more related to an electrical problem like an over heating contact or relay.
Posts: 5,110 Likes: 56
Black Rat Charter Member
Posts: 5,110 Likes: 56 |
Is the hole in the fuel cap blocked, take off the cap when it stops and see if it hisses.
My first thought Keith until I read the end of his first post.
