Topics49,843
Posts837,341
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
Not that particular one, but I use the Gunson Easibleed which works on the same principle (but gets it's pressure from a tyre - I tend to run it at 15psi).
Works very well for me and has done a great job on the Mog and Mg.
Posts: 36 |
I also have thé gunson, with some little modifications it is ok.
Plus 8 1991
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Another Gunson user here. Three watchpoints...... Good fit of the pipe from the bleed nipple to the container of fluid in a jar ( prevents air sucking back) Correct air pressure if using a wheel! Too much blasts fluid out, too little makes it slow. Check the reservoir bottle seals properly.
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
I can't be bothered with using the Esibleed anymore my solution is...
Chat up Mrs Cooper lady, install with a glass of vino in the drivers seat, pop Mog up on scissor lift, bleed...sorted !
Chat up Mrs Cooper lady, install with a glass of vino in the drivers seat, pop Mog up on scissor lift, bleed...sorted ! I tried something similar with Mrs TBM, but find the Easibleed calmer, quieter and more relaxing. She is not reknowned for her patience, which is understandable as she has to live with me.....
Chat up Mrs Cooper lady, install with a glass of vino in the drivers seat, pop Mog up on scissor lift, bleed...sorted ! I tried something similar with Mrs TBM, but find the Easibleed calmer, quieter and more relaxing. She is not reknowned for her patience, which is understandable as she has to live with me..... I suspect similar with Mrs FT!
Posts: 8,662 Likes: 408
Posts: 8,662 Likes: 408 |
Chat up Mrs Cooper lady, install with a glass of vino in the drivers seat, pop Mog up on scissor lift, bleed...sorted ! I agree with Jon. I bought a cheap hand vacuum pump bleed kit but it was pretty useless in sucking fluid through particularly on the rear. Anything that pressurises the master cylinder precludes easy checking and topping up of same.  's right foot method far superior.
Posts: 1,463 Likes: 98
Posts: 1,463 Likes: 98 |
. Anything that pressurises the master cylinder precludes easy checking and topping up of same. The Easibleed and the Sealey above have remote resevoirs that you pre-fill with brake fluid so no need to check and top up (unless you aim to drain an enormous amount of fluid ).
