3 members (JohnHarris, TalkMorgan, Graham, G4FUJ), 327 guests, and 97 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
#784238 22/08/23 04:17 PM
Has anyone tried this brake bleeding kit and if so, is it any good?
https://www.amazon.co.uk/Sealey-VS820-Clutch-Bleeding-System/dp/B000ROARTI?ref_=ast_sto_dp
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
TBM Offline
Not that particular one, but I use the Gunson Easibleed which works on the same principle (but gets it's pressure from a tyre - I tend to run it at 15psi).
Works very well for me and has done a great job on the Mog and Mg.
I also have thé gunson, with some little modifications it is ok.
Plus 8 1991
Another Gunson user here.
Three watchpoints......
Good fit of the pipe from the bleed nipple to the container of fluid in a jar ( prevents air sucking back)
Correct air pressure if using a wheel! Too much blasts fluid out, too little makes it slow.
Check the reservoir bottle seals properly.
I can't be bothered with using the Esibleed anymore my solution is...
Chat up Mrs Cooper lady, install with a glass of vino in the drivers seat, pop Mog up on scissor lift, bleed...sorted !
TBM Offline
I tried something similar with Mrs TBM, but find the Easibleed calmer, quieter and more relaxing. She is not reknowned for her patience, which is understandable as she has to live with me.....
TBM #784278 23/08/23 06:20 AM
I suspect similar with Mrs FT!
Morgan Plus 4
Brompton M6L
Giant TCX Advanced
I agree with Jon. I bought a cheap hand vacuum pump bleed kit but it was pretty useless in sucking fluid through particularly on the rear. Anything that pressurises the master cylinder precludes easy checking and topping up of same.
swmbo's right foot method far superior.
I have mates!
TBM Offline
The Easibleed and the Sealey above have remote resevoirs that you pre-fill with brake fluid so no need to check and top up (unless you aim to drain an enormous amount of fluid ).
