1 members (mph),
251
33
Topics49,911
Posts838,148
Posts: 317 |
Does anyone know how the larger and matte bezels below are attached to this black recessed panel? I have made bezels for the 10 smaller indicator lights above and I want to make these 4 larger ones in the same style. Can I simply pull out these bezels without any risk of damage to the the black panel? I don´t want to apply brute force here. Thank you for your inputs ![[Linked Image]](https://tm-img.com/images/2023/09/10/IMG_4956.md.jpeg)
2005 Roadster 3.0 S1 1960 MGA Roadster
Regards Aage
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Think after market ones are generally stuck on with some sort of mastic. You could try the “cheese wire” method using dental floss to cut through it. Alternatively simply drop the dashboard and look behind. 10 minute job.
Posts: 317 |
Think after market ones are generally stuck on with some sort of mastic. You could try the “cheese wire” method using dental floss to cut through it. Alternatively simply drop the dashboard and look behind. 10 minute job. Thank you
Regards Aage
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
IIRC the switch bezels are integral to the push switch outer, so be careful
Perhaps best to machine something thin that will sit over the existing 'ring'
Posts: 317 |
Perhaps best to machine something thin that will sit over the existing 'ring' Thanks
Regards Aage
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
I can confirm Coopermans info. The bezels are a part of the switch and cannot be taken off separately. To take it apart you will have to drop the dash and unscrew a sort of plastic nut that sits behind the switch. The switch then comes loose, bezel and all. Honestly, I do not think your little project is possible, hopefully I am wrong. By the way, if you really want something that stands out, change the black plate with Wolf Performances' veneer in turned steel or aluminium. Very elegant.
Med Morganhilsen, Robbie
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 317 |
Med Morganhilsen, Robbie Thanks Robbie- As I now know how these switches are put together, with the bezels integrated, my decision is very simple: Just leave these switches alone !
Regards Aage
Posts: 1,987 Likes: 104
Posts: 1,987 Likes: 104 |
...my decision is very simple: Just leave these switches alone ! God decision. Plus nobody else seems to have complimented you on the 10 small bezels you made, well done.
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 317 |
...my decision is very simple: Just leave these switches alone ! God decision. Plus nobody else seems to have complimented you on the 10 small bezels you made, well done. Thank you
Regards Aage
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Does anyone know how the larger and matte bezels below are attached to this black recessed panel? I have made bezels for the 10 smaller indicator lights above and I want to make these 4 larger ones in the same style. Can I simply pull out these bezels without any risk of damage to the the black panel? I don´t want to apply brute force here. Thank you for your inputs ![[Linked Image]](https://tm-img.com/images/2023/09/10/IMG_4956.md.jpeg) Late again! Here’s the EAO switches disassembled. The same as yours but with chrome plated brass bezels from a later car. Had the same dilemma on my first car. Made my own light bezels but the switch bezels weren’t worth the grief so stuck with the ali. ![[Linked Image]](https://dl.dropboxusercontent.com/s/ojx6d2xkv97cc43/dash2.jpg)
Roger 2011 Plus 4
