6 members (BobtheTrain, mickyb, tommog, TBM, Davetherave, Socalm3w), 241 guests, and 33 robots.
+8Rich 96
John V6 50
Topics49,901
Posts838,045
#785272 10/09/23 04:30 PM
Does anyone know how the larger and matte bezels below are attached to this black recessed panel? I have made bezels for the 10 smaller indicator lights above and I want to make these 4 larger ones in the same style. Can I simply pull out these bezels without any risk of damage to the the black panel? I don´t want to apply brute force here. Thank you for your inputs [Linked Image]
2005 Roadster 3.0 S1
1960 MGA Roadster
Regards Aage
westgardronning #785275 10/09/23 06:26 PM
Think after market ones are generally stuck on with some sort of mastic. You could try the “cheese wire” method using dental floss to cut through it. Alternatively simply drop the dashboard and look behind. 10 minute job.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Deejay #785278 10/09/23 07:27 PM
Thank you smile
1960 MGA Roadster
Regards Aage
westgardronning #785282 10/09/23 08:01 PM
IIRC the switch bezels are integral to the push switch outer, so be careful
Perhaps best to machine something thin that will sit over the existing 'ring'
CooperMan #785293 10/09/23 09:47 PM
Thanks smile
1960 MGA Roadster
Regards Aage
westgardronning #785297 11/09/23 05:33 AM
I can confirm Coopermans info. The bezels are a part of the switch and cannot be taken off separately. To take it apart you will have to drop the dash and unscrew a sort of plastic nut that sits behind the switch. The switch then comes loose, bezel and all. Honestly, I do not think your little project is possible, hopefully I am wrong. By the way, if you really want something that stands out, change the black plate with Wolf Performances' veneer in turned steel or aluminium. Very elegant.
Med Morganhilsen,
Robbie
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Robbie Mathisen #785304 11/09/23 08:11 AM
Med Morganhilsen,
Robbie
Thanks Robbie- As I now know how these switches are put together, with the bezels integrated, my decision is very simple: Just leave these switches alone !
1960 MGA Roadster
Regards Aage
westgardronning #785305 11/09/23 08:19 AM
Originally Posted by westgardronning
...my decision is very simple: Just leave these switches alone !
God decision. Plus nobody else seems to have complimented you on the 10 small bezels you made, well done.
Lordofthewings #785309 11/09/23 10:03 AM
Thank you smile
1960 MGA Roadster
Regards Aage
westgardronning #785353 11/09/23 05:34 PM
Rog Offline
Late again! Here’s the EAO switches disassembled. The same as yours but with chrome plated brass bezels from a later car.
Had the same dilemma on my first car. Made my own light bezels but the switch bezels weren’t worth the grief so stuck with the ali.
Roger
