6 members (Plus Four Guy, Luddite, GrumpyPa, Morganmike, deano, Hamwich), 152 guests, and 89 robots.
+8Rich 78
Topics49,871
Posts837,685
Rudolf
#785315 11/09/23 11:01 AM
Hawki Offline OP
Has anyone remover the centre console on a CX. I know the rear is simple by removing the surrounding trims from the gear knob and handbrake. What hold the front in place?
Just 2 lateral screws on each side on the top of center console bellow the dashboard (they also fix the lateral cache of the heater where sit the heated seat switch). Pay also attention on the « sport+ » button is connector is a bit in the way when you remote the center console.
Dada
(Sorry not a home actually to add a picture)
Dada,
Plus Six "Samantha" (the wooden witch)
Hawki Offline OP
Many thanks dada…most helpful
As I see you want to add some internal storage, you can easily do the following
Dada,
Do you have any pictures to show how you did it?
I think I have still the drawing with quotes, when back home middle of the week I will make some pictures and post.
Dada,
Unfortunately I was not able to find the final quotes and drawing but it’s quite easy to measure after dismounting the rear panel.
I request a local supplier to cut and bend me the “stair” in a 2 mm aluminium panel plus the two lateral panel in “L” solded laterally to close the « stair »
Cost 48 €.
There is no bottom, I just use a thick tissue to do the bottom.
The easy tip is to use the wood speaker mount to fix the assembly after the panel is put in place by just doing a 2mm cut in the wood to press the « stair » against the rear panel with the speaker srew.
Pay attention to two stuff :
- there is a rivet in the middle that is bellow the last frame so a little cut in the top of the « stair » is needed
- don’t forget to cut a 5x30 mm in the middle of the bottom of the stair to allow the cabling passage
For the rectangle hole in the panel up to you to see what is the best (I did it 40mm smaller that the « stair » and with the high needed to allow the passage of the anti-puncture cylinder.
Sorry for the bad wording I am French …
Dada,
