8 members (CooperMan, High Hamster, jbk, scortroadster, MJF, marshalben, DPEvans, ScottMellor), 243 guests, and 62 robots.
+8Rich 96
Posts837,260
Page 1 of 6 1 2 3 4 5 6
#786226 24/09/23 11:10 AM
sospan Offline OP
On the way home from Friday’s noggin the speedo, rev counter, fuel, temp gauges all cut out. No power so dark and needles all at the zero point.The LED screen was still working. Engine working fine and no warning lights came on. After a couple of miles the gauges came back ok but soon failed again. No other symptoms from the engine/ no warning lights/ engine running smoothly.
Fuses checked ok. Disconnected the battery to try a reboot. Still no gauges. Car starts as normal and sounds ok running.
Looks like a lost connection, module failure, behind the dash somewhere.
Car has done 4k+ miles since new a few weeks ago. The only glitch was the hood tenax stud fastener just behind the door snapped inside on the screw thread part.( mrs sospan replaced it unknown to me when I was raising the hood rear to put stuff onto the shelf) so replaced with a different one with two screw fixing holes. The originals are plated brass and seem to have a weakness for snapping and need drilling out. I think the newer version with stainless screws might be better, albeit two holes drilled to fit. I have done the broken side only so far to see how it goes before doing the other one.The procedure for the hood raising/ lowering now includes a verbal check on tenax release!
It’s going in to Williams for a handbrake check in just over a week so the gauges is another job for them!
sospan Offline OP
Looks like a loose connection?
Yesterday I checked and not working. I gently tapped the dash with my palm and bingo! Gauges ok. Today I was booked in at Williams for them to check. Dash off, all checked. Laptop check didn’t reveal any stored problems. Just needs watching for any repeats so a full tear down investigation can be done.
Handbrake was disassembled and checked. It does work but needs hard lever pulling!
This really looks like a loose connection. The worst errors are always those that are not reproducible.
Clemens
PlusFour Red Baron MY 2022
It reminds me of my first Morgan (a 1981 4/4). I always had to knock on the tachometer glass to wake it up after starting the engine.
Harald
Harald
My tacho has a duff earth somewhere. I switch the heater fan on for a minute which wakes the tacho up! smile
Yep Ohms Law never lets you down wink
I=V/R ?
Previous Mog Plus 4 Fiat Twin Cam.
Plus Six
I=V/R ?
I was at Uni with a girl named Ivy Watts blush
I=V/R ?
Did she put up any resistance?🤭
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Probably an open circuit hide
