6 members (Ian Wegg, britmog, Bishmog, James B W, Dada, Ulfulf), 288 guests, and 40 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,395
Members9,215
Rbt Aero8, Salmon, stevends
Page 7 of 15 1 2 5 6 7 8 9 14 15
Originally Posted by John V6
Quote
The 500ml can of Holts EGR cleaner was plenty for doing the valves. I also used some for cleaning the throttle body and the manifold, spraying into all the holes and swooshing it around several times - to get rid of any residual oil lurking on the internal surfaces. There's still a small amount of cleaner left in the can. It was considerably cheaper than some of the seemingly similar products such as Seafoam or CRC. It smells a bit like cellulose thinners and I was careful to avoid getting it on my hands.
For the S1 Roadster ford do not recommend cleaning the throttle body with such a spray as it can strip off the plastic coating on the body. It will be Iso propyl alcohol probably which is one of the thinners for nitro cellulose based inks & paints.
Thanks for that, John. Fortunately I used only a small amount and all on the inside, around the tract and butterfly - so only aluminium was involved. In fact there was very little black stuff in the throttle body anyway.
Keith
2017 Plus 4, deep blue
Struggling with a technique for squeezing the side tabs of the clip in order to pull the tube from the manifold spigot.
Cannot get any meaningful purchase with my fingers. Mole grips are too large and impeded by other pipes and cables. A pair of pliers impedes vision of what is going on. Any suggestions from good folk who have succeeded on this?
Before I have a further attempt, is the arrowed item on my pic below actually the clip in question?
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
^ try long nose forceps, the ratchet nr the finger holes allows it to the locked in place
Yes. you have the correct part. It is very awkward and I failed quite a bit before it finally succumbed. Try pushing it further onto the spigot before squeezing to release and pull off. Once the clips are released it comes off quite easily.
Keith
Thanks guys - some good tip’s there 👍
Shall persevere.
Chris
This was not a five minute job but eventually success came in detaching the breather connection. Detached the windscreen washer bottle to give some elbow room, placed a mirror on a wooden offcut wedged to the inner wing, hung a small torch from a heater tube, applied a good squirt of silicone spray on the clip and maneouved a small flat bladed screwdriver with the aid of the mirror to prize the clip off.
Next task will be to insert a bung into the inlet manifold hole - about 15mm ID. Then fix a long hose to the male portion of the plastic right angled connector - about 9.5mm ID. All done by feel with subsequent verification via the mirror!
I need a beer cheers
[Linked Image] :
Chris
Good final result though Chris. Hope you enjoyed the beer cheers
[Linked Image] :
Well done for getting it off. Surprised you needed to lever it off, but whatever worked is good. I found the OD of the inlet manifold connection to be around 12-13mm. I used this 13mm ID hose to make my connections and it was a very slightly loose fit, needing a hoseclip to make it tight and secure. https://www.amazon.co.uk/dp/B07NPH92J5?psc=1&ref=ppx_yo2ov_dt_b_product_details
Keith
Well done Chris
2025 MG ZS EV aka Trigger
DaveW Offline OP
Originally Posted by John07
Monty, Gloat away, that's fine.
DaveW, Whilst some of the oil on the backs of the valves will come from the breather some will also come down the valve guides, IMHO.
Cheers
Totally agree John, in fact a significant amount of oil residue is likely to arrive that way. With low mileage engines, the crankcase won't be "pressurised", but the oil droplets will get sucked through, although my breather wasn't oily at all.
We're stuck with this design fault, and I suppose all we can do is use decent oil, and keep an eye on it.
