4 members (lez, High Hamster, RichardV6, Martin W), 246 guests, and 60 robots.
+8Rich 76
Topics49,859
Posts837,513
Jonny72
#788401 21/10/23 01:45 PM
TimG Offline OP
I was watching a programme on Isambard Kingdom Brunel & they showed his drawing instruments, just like the ones I have. They were used by a relative of mine a joiner born 1846. I used them in school.
I dug them out & found that the foam I had used to cushion them had disintegrated & has marked some of them. I have tried methalated spirit & WD40 to clean them. Has anyone suggestions what to do to clean them?.
https://tm-img.com/image/SVumS
https://tm-img.com/image/SVG9H
Try nail varnish remover. Usually contains acetone.
Acetone should help. A good metal polish also.
Or an ultrasonic jewellery cleaner.
They are similar to my 1970s set from uni.
TimG Offline OP
I've not got any acetone but I'm trying wrapping in isopropyl alcohol soaked rag which seems to be helping remove the green. I want to try avoiding polish as I think the finish should be dull.
I remember doing a draughtsman apprenticeship with a right-handed drawing board and parallel arm fed set square. It was a bit awkward being left-handed.
Best Regards
Lang may yer lum reek
Nail polish remover was always acetone ... unless they've messed with it for some reason. Lost count of the number of times I've had to look innocent after a cleaning job when Mrs Image was looking for hers 🙂
