7 members (RubyMog95, mph, JohnHarris, Fuel.inj, Luddite, DCH, Saxonian),
284
76
Topics49,877
Posts837,713
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
I’ve started my winter jobs early. Wing off to get the running board off for painting again as it started to blister up. Got me thinking about these huge CATs. I was going to get a bypass pipe made for the secondary as I want more noise. It looks so big I reckon it could cause emission issues come MOT. Someone suggested punching out the internals of the smaller CAT. Has anyone tried this? Another job is the repaint the calipers as they’ve faded but I’m not skilled enough to delicately paint around the engraving. Will see. ![[Linked Image]](https://tm-img.com/images/2023/10/24/DA3145FF-98B1-4172-836B-397661CA56BD.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/10/24/8EB787C4-C8DD-43C6-B96D-65DE286BFD94.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/10/24/AC5AB67B-D758-4FDD-A36B-45E97933AB43.jpeg)
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
you could use a thinly coated sponge roller on the flat logo area and a brush for the rest?
1993 T16 +4 Lancia Blue.
you could use a thinly coated sponge roller on the flat logo area and a brush for the rest? That’s not a bad idea. Thx
Posts: 8,684 Likes: 414
Posts: 8,684 Likes: 414 |
I've had great results with faded indented logo's using the following method:
After repainting the whole main body and allowing plenty of time to not only dry but harden, the logo can then be brush filled in with contrasting paint that works with white spirit as solvent. Excess paint can then be wiped off with single stroke of clean tissue lightly soaked in white spirit.
After repainting the whole main body and allowing plenty of time to not only dry but harden, the logo can then be brush filled in with contrasting paint that works with white spirit as solvent. Excess paint can then be wiped off with single stroke of clean tissue lightly soaked in white spirit. Yeah I had that thought earlier. It’s an option. I might try some rubberised masking fluid.
Sorted. So skilled  ![[Linked Image]](https://tm-img.com/images/2023/10/29/4DD0E584-8817-48E5-9043-88D85940589B.jpeg)
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
Sorted. So skilled  ![[Linked Image]](https://tm-img.com/images/2023/10/29/4DD0E584-8817-48E5-9043-88D85940589B.jpeg) don't keep us in suspense  - what method did you use....? Looks great by the way  James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Loool I used Humbrol Maskol. Kind of rubberised liquid. Smells like Copydex.
Filled the engraving with it. Painted the calipers lightly (on the fronts) used a toothpick to peel the masking out while the paint was semi dry them Matt lacquered them.
Filled the engraving with it. Painted the calipers lightly (on the fronts) used a toothpick to peel the masking out while the paint was semi dry them Matt lacquered them. - not seen that before ; sounds useful  James
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
Filled the engraving with it. Painted the calipers lightly (on the fronts) used a toothpick to peel the masking out while the paint was semi dry them Matt lacquered them. - not seen that before ; sounds useful  James I used the white spirit method but you do it whilst the paint is still well. ![[Linked Image]](https://www.tm-img.com/images/2022/02/22/44D4FA3C-8534-4A60-A06D-E0D2363EC1FD_1_105_c.jpg)
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
