7 members (JMcL, DCH, IcePack, scortroadster, Zach, Burgundymog, nick w),
244
89
Topics49,847
Posts837,389
Posts: 23 |
For reasons I don't understand, my M3W does not have the P090037 ECU COVER PANEL (the rectangular box to the rear of the battery, protecting the ECU/Fuse box/etc). Hopefully the link below works.
Does anyone have a drawing for the panel to have one made, or suggestions about where I might get one?
Thank you, Tim
[img]https://www.google.co.uk/imgres?imgurl=https%3A%2F%2Fwestmogmidsummer2016.files.wordpress.com%2F2016%2F10%2Fctek-m3wck.jpg&tbnid=54b-I3tensv9MM&vet=12ahUKEwiFyp3alqOCAxWzV6QEHSpdCYsQMygAegQIARB8..i&imgrefurl=https%3A%2F%2Fwestmogmidsummer2016.wordpress.com%2F2016%2F10%2F26%2Fgarage-56-springs%2Fctek-m3wck%2F&docid=WRaNeYBCuwruJM&w=576&h=432&itg=1&q=m3w%20battery&ved=2ahUKEwiFyp3alqOCAxWzV6QEHSpdCYsQMygAegQIARB8[/img]
Posts: 396 Likes: 44
Posts: 396 Likes: 44 |
This picture? ![[Linked Image]](https://westmogmidsummer2016.files.wordpress.com/2016/10/ctek-m3wck.jpg)
Ian S
2019 Sports Green Plus 4 2025 Hyper Blue Mercedes 180 CLA
Posts: 23 |
Yes - Thank you. I could not find a way of posting it!
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
For reasons I don't understand, my M3W does not have the P090037 ECU COVER PANEL (the rectangular box to the rear of the battery, protecting the ECU/Fuse box/etc). … Presumably someone forgot to refit it? Any chance you can check with previous owners or garages?
Posts: 23 |
I suspect that you are right. That is effectively the factory, and they did advise me on last service that it would be expensive (for them) to produce one - as they are out of production.
Posts: 23 |
Eddy,
That is fantastic. What material did you use (thickness primarily).
Thank you, Tim
Posts: 77 Likes: 3
Posts: 77 Likes: 3 |
It´s aluminium 1,5mm thickness
Eddy
built not bought - hustled not handed - earned not given - rare not average
Posts: 23 |
Eddy,
I am investigating if I can get someone to produce this from the file (this is unfamiliar territory to me!). I will get back to you if I can.
Thank you again for your help, Tim
Posts: 77 Likes: 3
Good Mornging Tim,
every metal workshop with a laser cuting and bending machine can work with this files ... should be normaly no problem!
Eddy
