7 members (SteveT, Tony Quinn, Ian Wegg, TeddyAds, GBpluseight, TBM, Grumpy2), 187 guests, and 38 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,354
Christoph
Page 1 of 4 1 2 3 4
#789210 01/11/23 04:07 PM
For reasons I don't understand, my M3W does not have the P090037 ECU COVER PANEL (the rectangular box to the rear of the battery, protecting the ECU/Fuse box/etc). Hopefully the link below works.
Does anyone have a drawing for the panel to have one made, or suggestions about where I might get one?
Thank you, Tim
[img]https://www.google.co.uk/imgres?imgurl=https%3A%2F%2Fwestmogmidsummer2016.files.wordpress.com%2F2016%2F10%2Fctek-m3wck.jpg&tbnid=54b-I3tensv9MM&vet=12ahUKEwiFyp3alqOCAxWzV6QEHSpdCYsQMygAegQIARB8..i&imgrefurl=https%3A%2F%2Fwestmogmidsummer2016.wordpress.com%2F2016%2F10%2F26%2Fgarage-56-springs%2Fctek-m3wck%2F&docid=WRaNeYBCuwruJM&w=576&h=432&itg=1&q=m3w%20battery&ved=2ahUKEwiFyp3alqOCAxWzV6QEHSpdCYsQMygAegQIARB8[/img]
This picture?
Ian S
2019 Sports Green Plus 4
2025 Hyper Blue Mercedes 180 CLA
Yes - Thank you. I could not find a way of posting it!
Originally Posted by Tim Rice
For reasons I don't understand, my M3W does not have the P090037 ECU COVER PANEL (the rectangular box to the rear of the battery, protecting the ECU/Fuse box/etc). …
Presumably someone forgot to refit it? Any chance you can check with previous owners or garages?
PaulV #789263 02/11/23 10:15 AM
I suspect that you are right. That is effectively the factory, and they did advise me on last service that it would be expensive (for them) to produce one - as they are out of production.
Hi Tim,
I had the similar problem ... and I made one new part for me ... see enclosed pictures.
https://www.dropbox.com/scl/fi/iwy5...rlkey=o4q2yjhljwj71ip3kjl5t55m3&dl=0
https://www.dropbox.com/scl/fi/91zq...rlkey=cna7yf99aqpyubnnby417o8t8&dl=0
I can share the dxf file for the laser cutting machine with you!
Eddy
built not bought - hustled not handed - earned not given - rare not average
1 member likes this: gomog
Eddy,
That is fantastic. What material did you use (thickness primarily).
Thank you,
Tim
It´s aluminium 1,5mm thickness
Eddy
Eddy,
I am investigating if I can get someone to produce this from the file (this is unfamiliar territory to me!). I will get back to you if I can.
Thank you again for your help,
Tim
Good Mornging Tim,
every metal workshop with a laser cuting and bending machine can work with this files ... should be normaly no problem!
Eddy
Page 1 of 4 1 2 3 4
