1 members (jejemek),
223
35
Topics49,844
Posts837,360
Posts: 23 |
Any insight into what the connector might be is welcome. That aside I am planning to disconnect the battery and then see if the "extra" block can be relocated. Will report back.
Tim
Posts: 23 |
This is the extra block on the side of the 50A Fuse Block. The cables are Red and Red/Yellow (althoug it could be Orange/Yellow). Icannot find that combination on the wiring diagram, which might be because it was a modification. There appears to be some movement between the two, but I cannot find how to separate them - any suggestions? Thanks, Tim ![[Linked Image]](https://www.tm-img.com/images/2023/11/05/IMG_6244.jpeg) ![[Linked Image]](https://www.tm-img.com/images/2023/11/05/IMG_6253.jpeg) ![[Linked Image]](https://www.tm-img.com/images/2023/11/05/IMG_6251.jpeg) ![[Linked Image]](https://www.tm-img.com/images/2023/11/05/IMG_6237.jpeg)
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Ease a thin flat screwdriver up from the bottom centrally between the two, you may have to pry apart a little then the 'extra' feed base should slide off up/down (you can see the clip & slider on the exposed end, they are designed to 'stack')
Posts: 23 |
Jon, Work a treat. Probably saved a few swear words and my knuckles! Thank you, Tim
Posts: 23 |
Is there an established way of attaching the "additional block" to the side of the fuse box (which it will locate too easily and still leave room for the cover? Thanks. ![[Linked Image]](https://www.tm-img.com/images/2023/11/03/Fuse-Box.jpeg)
Posts: 1,982 Likes: 103
Posts: 1,982 Likes: 103 |
Is there an established way of attaching the "additional block" to the side of the fuse box Try velcro - available in strips (male & female sides) about an inch or two wide. From old-fashioned haberdashers or online. Use Evo-stik to secure each piece in place.
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 23 |
Peter, Thanks - will do that. Tim
Posts: 77 Likes: 3
Posts: 77 Likes: 3 |
Eddy,
Yes - I have found someone, although they are suggesting water jet cutting. Could you give me the approximate dimensions of the box? I wouldn't want to get it produced and then find that Morgan modified things between producing our cars! BTW mine is 2015. Thanks, Tim Hi Tim, sorry for the late answer ... I was a week in China and did a lot of supplier visits (so no free time). In the dxf file you can find the needed dimensions - but I would suggest you wait a while: I´m just work on a new design which has a removable cover on the top side. In this way you do not have to remove the complete cover if you need to replace some a fuse.
Eddy
built not bought - hustled not handed - earned not given - rare not average
Posts: 23 |
Eddy,
No apology necessary. I have found that my bulkhead does not have the tapped holes for the cover attachment bolts. I have learned from a former employee, that my M3W may have been a development vehicle, which might explain why it did not have a cover in the first place.
I am investigating......
Tim
