Topics49,839
Posts837,302
Posts: 3,847 Likes: 399
Posts: 3,847 Likes: 399 |
It may be me.. .. our heater in the Plus Six seems to work a little faster from cold since its 3rd radiator and ECU reflash for the revised control of the engines rotary water flow valves.. The engine certainly now warms up much more progressively. Prior to the reflash the engine would come up to working temp and then dip temp as the cooling went to the radiator then come back to normal temp.. Maybe its reduced the thermal shock caused by the previous ECU software.
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 2,432 Likes: 66
Posts: 2,432 Likes: 66 |
We had the ecu reflash a few weeks ago exactly as Dave describes, hot air around the tootsies though is poor and we need some sealing around the bottom of the doors which might help the situation, Em
Posts: 564 Likes: 79
Posts: 564 Likes: 79 |
We had the ecu reflash a few weeks ago exactly as Dave describes, hot air around the tootsies though is poor and we need some sealing around the bottom of the doors which might help the situation, Em Hi Em, ref your door seals.. Not sure what year your Plus Six is, but ours is late 2020, originally on our Plus Six the door seal from the lock area that then goes down along the bottom of the door and up to 1/3rd at the front was a thin'ish seal. Ours did not seal very well, so the dealer fitted a pair of the larger updated lower door seals which came into production around early 2022 ( I think ) . The later door seal is about 10mm wide and slightly thicker, it is a lot wider than the earlier type. These have worked well. I also found there was a seal gap with the sidescreens fitted in the area above the door lock. By inserting a section of round neoprene up and into the end of the existing hollow sidescreen seal in that area and extending it down to the height of the door sealed the gap very well and it almost looks "factory" fit. I can send you some photos of it all if you are interested..
Early 2020 Dave. photos would be good thank you. Em
Hi Em, I have just sent you a PM. Dave
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
It may be me.. .. our heater in the Plus Six seems to work a little faster from cold since its 3rd radiator and ECU reflash for the revised control of the engines rotary water flow valves.. The engine certainly now warms up much more progressively. Prior to the reflash the engine would come up to working temp and then dip temp as the cooling went to the radiator then come back to normal temp.. Maybe its reduced the thermal shock caused by the previous ECU software. Yep, the extreme thermal shock was a significant factor in the early rad failures
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
Biggles - would you please send a copy to rsyme2627@gmail.com - thanks
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Why not post the photos here? I'm sure some people here will be interested
Clemens
PlusFour Red Baron MY 2022
Hi Clemens, I have not yet mastered the technique to post them... I will reserve some time to it over the weekend and see what I can do..
Posts: 91 Likes: 2
Posts: 91 Likes: 2 |
On the subject of heating, what are chaps views on the amount of airflow coming from the lower vents. My flow is minimal & yes, I have selected the lower vents!
