14 members (vbalddave, 2949olivier, Fuel.inj, Montegue, nestor59310, Image, Alan Patterson, Strathaven, nick w, stumog, +8Rich, MartinB60, Guten, Graham, G4FUJ),
287
42
Posts837,283
Posts: 99 Likes: 5
Posts: 99 Likes: 5 |
Hi all - does anyone know where I can get a drive belt retaining ring for the rear sprocket (2017 M3W) I have tried the usual suspects but can only get a rear sprocket (at 1000 pound this seems to be an uneconomical way to get hold of one.....) Cheers,
M3W 2017 Sport blue.
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
The retaining rings really are superfluous if the alignment of the sprockets is correct. I'm running an alloy sprocket with no retaining rings at all, with no issues.
Why do you feel the need to fit a retaining ring?
Steve Late 2012 M3W
Posts: 99 Likes: 5
Everything is lined up but I still get 3mm of overhang. I can live without it but if I could get one O would use it.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
As Bitsobrits says, the outer retaining ring on the rear sprocket is really not required. Early M3W's never had them fitted from new and some owners have removed them from later cars to reduce belt noises from slightly out belt alignment. If you can get one or have one made, no problem but I wouldn't let it stop you using the car. About 3 mm overhang on the rear sprocket is what the early M3W's usually had, although they also had the silver hub rather than the later black one your car will have.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Don't get hung up about 3mm of belt overhang mine has been like that for 22k miles without any adverse effect.
Posts: 698 Likes: 7
Toys for Boys Talk Morgan Regular
Posts: 698 Likes: 7 |
It’s not necessary as others have said, but If you really want one I have a pile of them removed for Supermax sprocket conversions, drop me a private message.
Omne trium perfectum
2 members like this:
Taffmog, Stevo666 |
