4 members (Ricosan, Ian B, ChrisConvertible, +8Rich), 450 guests, and 88 robots.
+8Rich 82
Topics49,849
Posts837,423
DazMog, The Impaler, tlchzj79
#792186 16/12/23 04:18 PM
Alfredo Offline OP
Hello.
I am rebuilding a 4/4 Morgan 1964 and now I am working in the chassis. I've read that in later Morgans, the factory adds some parts to reinforce the chassis. Somebody can give more information? Regards
Ray Offline
There is a couple of metal plate fillets welded where the chassis side rails join the first cross member at the back of the engine bay.there might b same at the rear of the side rails. Can't think of anything else at the moment.
Someone recommended horizontal gussets where the chassis meets the crossmember at the firewall...
Ray Offline
Those are the ones i meant.
1 member likes this: 1854sailor
Alfredo Offline OP
Thank you very much. I'll put that. Have a nice weekend
If you don't have them also fit brake reaction bars.
Will you upgrade from lever arms at the rear?
Alfredo .... these ... I made new ones when I was doing my resto as the old ones had a bit of tinworm 🙂
Make them larger than the original on the earlier cars - the later chassis had longer plates giving greater support to the front chassis legs.
Alfredo Offline OP
Thank you for your comments, John, Image and Graham. Happy holidays. AFG
xmasgrin cheers
