SORN
Topics48,376
Posts813,549
Members9,215
Posts: 5,057 Likes: 318
Posts: 5,057 Likes: 318 |
Wouldn't presume they're reset-on-power down ...The zero-volt switches on machine tools do, but other latching switches are mechanically latched and just toggle between on and off each time they're pressed ....so would stay in whatever state they were regardless of ignition status.
Posts: 1,961 Likes: 43
Posts: 1,961 Likes: 43 |
Muchos thanks to you both Rog and dejay!
I presume the latching switches will cancel if you switch off the electric's/engine ie. self cancelling if power is lost? I'll start sorting all the parts and getting ready to swap out the PCB. I so want the car to get me into old age and cause me as little trouble as possible and when my son finally get the keys I don't want his learning curve to ruin his ownership pleasure! A latching switch does what it says…when the button is pressed to ON, it stays in that state until the button is pressed again to go OFF. However, the electrical supply may well be cut if it is sourced via the car ignition switch when that is turned OFF. But when you turn the ignition switch again to ON, items controlled via the push button either directly or via a relay coil, will come on again, until it is pressed once again to the OFF position. So having buttons or switches that light up when ON is very useful in reminding you that items are still switched on. Good luck with your task but bear in mind that there is a fair amount of soldering and crimping activity involved in a tight space, together with searching for the correct wires hiding in the loom!
Posts: 7,949 Likes: 221
Posts: 7,949 Likes: 221 |
I presume the latching switches will cancel if you switch off the electric's/engine ie. self cancelling if power is lost? I'll start sorting all the parts and getting ready to swap out the PCB. I so want the car to get me into old age and cause me as little trouble as possible and when my son finally get the keys I don't want his learning curve to ruin his ownership pleasure! You wouldn't want a hazard switch to self cancel on engine off. Thankfully this is not the case with the mechanical latching switches being discussed. 2014 on Classics use momentary switches though with electronic logic latching. This usefully cancels selection of rear fog light, screen demist etc. on engine off, the exception being hazard switch of course.
Posts: 1,639 Likes: 20
Posts: 1,639 Likes: 20 |
2014 on Classics use momentary switches though with electronic logic latching. This usefully cancels selection of rear fog light, screen demist etc. on engine off, the exception being hazard switch of course. I fear our woes began as earlier as 2003 with the introduction of ‘smart’ momentary latching and the ‘clever’ dash PCB using a micro controller. What was ever wrong with a simple rocker or toggle….. 2003 Plus 8 ![[Linked Image]](http://tm-img.com/images/2023/12/21/lemans.jpeg)
Roger 2011 Plus 4
Especially in a Morgan ... by their nature Morgan owners have made a deliberate choice for anachronism ... if you're happy with living with a Morgan in the first place then proper toggle switches are just part of the deal and unlikely to be a deal-breaker .... Whereas failing and irreplaceable quasi-modern electronics are definitely going to tick people off
2014 on Classics use momentary switches though with electronic logic latching. This usefully cancels selection of rear fog light, screen demist etc. on engine off, the exception being hazard switch of course. I fear our woes began as earlier as 2003 with the introduction of ‘smart’ momentary latching and the ‘clever’ dash PCB using a micro controller. What was ever wrong with a simple rocker or toggle….. 2003 Plus 8 ![[Linked Image]](http://tm-img.com/images/2023/12/21/lemans.jpeg) Yes maybe a step too far too soon  . Seems to be reliable on the BCU controlled models though as with every new car on the road now. We saw yesterday the latest CX models now have auto lighting control with sensor just behind bonnet hinge. Whatever next
I presume the latching switches will cancel if you switch off the electric's/engine ie. self cancelling if power is lost? I'll start sorting all the parts and getting ready to swap out the PCB. I so want the car to get me into old age and cause me as little trouble as possible and when my son finally get the keys I don't want his learning curve to ruin his ownership pleasure! A latching switch does what it says…when the button is pressed to ON, it stays in that state until the button is pressed again to go OFF. However, the electrical supply may well be cut if it is sourced via the car ignition switch when that is turned OFF. But when you turn the ignition switch again to ON, items controlled via the push button either directly or via a relay coil, will come on again, until it is pressed once again to the OFF position. So having buttons or switches that light up when ON is very useful in reminding you that items are still switched on. Good luck with your task but bear in mind that there is a fair amount of soldering and crimping activity involved in a tight space, together with searching for the correct wires hiding in the loom!Having read this "wires hiding in the loom", the pics below might be useful. Here’s which bundles are hiding the relevant wires. ![[Linked Image]](http://tm-img.com/images/2023/12/21/wirelocation.jpeg) And this is the original G55 wire (the one that has to be removed). I didn’t totally remove my G55, I just pushed the contact/spade out of the connector and parked it in the spare slot behind its original position. Luckily the spare slot connects to nothing and easy to convert back if needed. ![[Linked Image]](http://tm-img.com/images/2023/12/21/wire-g55.jpeg) A word of caution too for anybody following the wiring diagrams in the parts book... These connector didn’t exist in my 2011 car. ![[Linked Image]](http://tm-img.com/images/2023/12/21/elecdia1.jpeg) It was actually more like this ![[Linked Image]](http://tm-img.com/images/2023/12/21/elecdia2.jpeg)
Roger 2011 Plus 4
Posts: 7,914 Likes: 243
Posts: 7,914 Likes: 243 |
Over the months this thread has become even more fascinating, some very clever people involved, especially Rog, keep up the good work chaps
Thanks Jon  We must have just about flogged this one to death by now….
Roger 2011 Plus 4
Posts: 694 Likes: 62
Posts: 694 Likes: 62 |
Again thanks all for this excellent information, thanks Richard for the clear explanation of mechanical and momentary latching differences and which system uses which!
Rog, an excellent visual on the wire locations!
