8 members (Clipper, Robbie, Alistair, linklaw, Morganmike, gaston, JohnHarris, DaveW),
309
37
Topics49,837
Posts837,288
Posts: 72 |
Thanks again Steve.
Andy my existing filter is insulted from the bracket so I will do the same on replacement.
Gordon
2013 M3W 1972 MGB Roaster 1967 Morris Mini Super Delux
Posts: 72 |
Gordon
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
Curious as to what type of insult you used, mild or strong
1 member likes this:
Bitsobrits |
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Curious as to what type of insult you used, mild or strong  One with a British accent or American???
Posts: 72 |
Point taken from our friends on the other side of the pond.
Gordon
Posts: 99 Likes: 1
Posts: 99 Likes: 1 |
I have just replaced the fuel pump and filter on my 2012 3W. On the exact same hose as shown in the photo from RoyG, that hose as well as all the others came off using Knipex pliers as suggested in the great article by Ian Brett & Andrew Warren back in April 2020.
However, when reconnecting that hose it is not locking on like the others. Did not notice until trying to start the engine and it blew off spraying fuel.
Is there a way to solve this short of a new line?
Tks.
TomS
Posts: 79 Likes: 23
Posts: 79 Likes: 23 |
When you are talking about using the old "Quick-connect", maybe this is a solution. It worked for me alternative for a quick-connect
One ant does not know anything, 2000 are a super-intelligent brain. That's like this helpful forum.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
It sounds like you have damaged the quick release fitting as they usually just snap back on with no problems about security or leaks. I have not tried Herries fix but it looks good to get you going. I would be replacing the end fitting if it isn't working properly. They are available on eBay, if you look up "Bundy Type 7.89mm ID6". There are several different end fittings, some have much easier to press release buttons.
