3 members (RichardV6, BLUE+4, Mick Annick), 294 guests, and 39 robots.
John V6 68
+8Rich 66
DaveW 64
9,208 Registered Users
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,346
Posts813,054
Captain Morgan, IRWIN
Page 1 of 6 1 2 3 4 5 6
DZK Offline OP
I’ve read a lot about the chassis defects of the pre 2014 cars. And through my work as an engineering planner I know the importance of weld technique and post weld heat treatment to give reliable results. I understand morgan changed design and materials in 2014. But I’m wondering how many cars like my 2012 have not had an issue? Is it a given that it will crack? Or were some more prone to it because of how the weld went on the day.
So if you still run an original 2012-14 chassis please let me know. drive
Material and chassis changed in 2013 to change material and add gussets (not just in concerned area) then revised again in 2014 to include welded in triangular brace as opposed to the bolted in one and move the regulator position, maybe a few other tweaks.....I believe they have still been know to crack on the lower upright though, pot holes or pot luck maybe
mine is late 2013 and no issues so far
There were 1027 pre-2014 specification cars produced, according to the numbers for the one and only M3W recall, to date. That was for brake pedal weld failure but was also supposed to incorporate the chassis crack checks at the same time as the brake pedal inspection, although no mention was made of this in the recall information. There were far fewer cars fitted with the suspect brake pedal box than 1027. DVSA were of the opinion that these chassis cracks would not result in a catastrophic failure, you would get an indication something was wrong, so would not issue a recall for the chassis cracking.
As you say, a good proportion of those cars have had chassis replaced for cracks in the tubes near the upper wishbone rear mount, along with some accident replacements. I couldn't even guess at a number though. The cracks do tend to start from a weld, so the quality (on the day?) of weld may have something to do with it? The specification of the chassis tube was also changed in 2014. From personal experience of fitting an Empire suspension kit to both pre and post 2014 chassis, the later chassis was made to better tolerances than the early one, which required lots of shims to correct the geometry from side to side.
Some chassis don't crack for many miles and others crack at fairly low mileages, there is no set usage for failures. When they do crack propagation of the crack can be quick. I have checked a chassis closely for cracks and found nothing, then found the tube fractured within a thousand miles. You can be fairly sure that a pre 2014 spec chassis will crack at some point, sooner or later. The bolt in brace seems to make little difference, the welded in version that some early cars got seems better. All M3Ws, right up to the last ones made, can crack in the vertical tube at the lower wishbone front mount and can be relatively easily and cheaply fixed with a welded repair bracket.
For info, MMC have recently changed their policy with chassis cracks on early M3Ws, no longer will they replace them free of charge. A "customer contribution" in the region of £10,000 is now required, plus payment for any other work found during the chassis change. There are alternatives, repairs from M3W Services for example. Sorry for the long answer 😊.
DZK Offline OP
Thanks Planenut. I wish Morga n would confirm how many they’ve replaced. If it’s a hundred then it’s only 10%
Mine is chassis 003, repaired / welded FOC at factory.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
mph Offline
Originally Posted by DZK
Thanks Planenut. I wish Morgan would confirm how many they’ve replaced. If it’s a hundred then it’s only 10%
Planenut is on the money when he says "You can be fairly sure that a pre 2014 spec chassis will crack at some point,"
This is the premise I would work on, irrespective of any figures that can be extrapolated from the MMC.
A few pictures of chassis cracking on my ex 2012 M3W ,11000 miles
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
On the other hand when I traded it in for a new one, my 2013 M3W had 35,000 miles on it (including several track days) without cracking.
Red Leader drive
It would be helpful if more pictures showing area's subject to cracking were posted
Gordon
2013 M3W
1972 MGB Roaster
1967 Morris Mini Super Delux
DZK Offline OP
Ok that's 2 out of 1027. its a start :-)
