Topics49,844
Posts837,360
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
pleased to see you back Tim. Thanks Paul. Been more than a bit busy with other projects.
Posts: 792 Likes: 143
Posts: 792 Likes: 143 |
A dial micrometer with tube inserted into a spark plug base. This was screwed into centre plug two stroke cylinder head to determine piston position btdc for setting ignition timing on contact breaker points. Used with battery and light bulb in 1970s.
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 1,982 Likes: 103
Posts: 1,982 Likes: 103 |
I like this thread. Here's a variation: what do you reckon these tools are for ? (clue: not a Morgan....) ![[Linked Image]](https://www.tm-img.com/images/2024/02/04/Tools.jpeg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 8,664 Likes: 408
Posts: 8,664 Likes: 408 |
Here's another very infrequently used tool. Clearly an instrument, can anyone guess it's primary purpose? ![[Linked Image]](https://i.imgur.com/ScpKx6t.jpg) Sometimes it's enough just to own such beautifully made instruments.
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
Google has told me it's a vintage tachometer, but that's a far as my knowledge goes! One on ebay for £20 if anyone fancies one https://www.ebay.co.uk/itm/295936430444
I've got a whole stack of very specific tools that probably I've only used once or twice, but made the job much much easier - spring clamps. rotax engine locking tool, MT500 bearing press, MG rear brake cylinder tool, Kawasaki Fork seal tools, Land Rover hub nut spanner, AN braided hose stuff.......
That's what I last used it for TBM, measuring the idle speed of a vintage Lister JP2M diesel in my narrowboat. It mechanically counts the number of revolutions over a preset period of a few seconds then the needle freezes with a read out. Primary use was measuring lathe leadscrew speeds for thread cutting. It came with a full set of printed tables for such.
Sometimes it's enough just to own such beautifully made instruments. Certainly is. That's lovely, isn't it?
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
I just can’t bring myself to get rid of tools, some of which I’ve owned for over 50 years. So: AF & Whitworth Socket Sets and an Imperial Micrometer, along with a selection of BA fasteners, still grace my toolbox.  Bud 4/4 - Stanley
Bud 4/4 "Stanley"
