0 members (), 365 guests, and 84 robots.
+8Rich 76
DaveW 52
Topics49,867
Posts837,614
Moggo
#795285 05/02/24 07:58 AM
Neil49 Offline OP
Gentlemen,
My clock has died. I have removed it and put 12V across it, but the second hand clicks one second then stops.
Its a 'MotoMeter' brand, 'Quarz - Zeit' type, 52mm diameter where it goes through the dash. I suspect it is original.
I have sent an email to Melvyn's spares man, but does anyone have any suggestions?
Neil
+4 1986 - Royal Ivory / Blue
Volvo 123GT 1967 - Pearl White / Brown (pristine and very rare)
Any good?
I have exactly this Smiths clock in my 4/4 and it runs perfect on time, easy to read! Better than the clock in my new PlusFour, which is hard to read!
Ruut Bianchi
Neil49 Offline OP
Thanks Richard, it may do but please allow Melvyn to reply.
Neil49 Offline OP
i am trying to keep it as original as possible.
TBM Offline
If you're desperate for original, it might be better to see if it can be repaired, or transfer the workings for a smiths one into the original housing.
With such a small overall demand, I would not be surprised if an “original one” is sourced from the same makers as all others. . Only difference will be the mark-up, which may be considerable!
One other thing to take note of, if you buy a replacement and that is the bezel shape. Half round or vee. You may need to swap from your old one to make it match, before you install.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Contact caerbont. They could repair or supply another. They set up when the Smiths factory closed.
www.caegauge.com
Re the PlusFour clock, mine in the MY23 worked ok but not lit up. Apparently fairly common. I had a new pcb fitted when all the gauges failed and it now lights up.
Try Europa spares for replacement or Caerbont or Speedy cables in Swansea for repair
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
