7 members (GrumpyPa, JohnHarris, DaveW, JMcL, +8Rich, Burgundymog, Arwyn Williams), 242 guests, and 59 robots.
Posts837,257
Page 15 of 15 1 2 13 14 15
Good result, the spare gauges could be useful
Indeed Jon.
TBH £200 to sort out all the missing warning lights and get back the heater fan, the heated screen, and the MoT esential fog light, was well worth it. I've heard tales of people paying upwards of £500 for a new PCB (when they were still available from Morgan), and some buying more than one having suffered multiple failures frown2
These tales of woe puts it all into perspective, so I'm viewing the spare gauge set, knobs, switches, clock and dash that came free with the switch panel/PCB I needed as an unexpected bonus thumbs
The PCB delete developed by Rog remains the best solution though, it's more work but ultimately cheaper as relays are inexpensive, and the PCB is completely removed. However, for me, £200 for a used improved fuse protected PCB off a late model 4/4 that I was able to fit in 1.5 hours was the best solution thumbs
Rog #817304 11/02/25 09:57 AM
Rog Offline OP
Originally Posted by Montegue
Interesting sherlock
It seems Morgan understood there was an issue and were starting to add PCB protection, if not a fix ooo
Nice find Dave, what a bargain thumbs
If my memory serves me correctly this was a supplementary loom that appeared on some cars and carried additional fuses for the O/S and N/S indicator lamps. I believe their function was to protected the PCB's fragile tracks from the full 15A/20A supply when there was a fail/short/water ingress in the indicator lamps. Certainly a nice to have extra but they have caught people out when they have blown in the past as there is no circuit diagram reference to them tucked away behind the dash.
In principle it would be a simple mod to add a couple of fuses to the wires entering the 12 pin PCB connector, wires GR90 and GW86.
Not sure if these fuses would address any of the other PCB shortfalls such as the the suspected back EMF or spikes from the blower motor taking out certain components, for one.. ooo.
Roger
Rog #817306 11/02/25 10:12 AM
Rog,
For those not electrically empowered/knowledgeable, this has been an excellent but very long thread, I have despite reading several times lost my way in all the exchanges as to what is really required and the component listings to make PCB redundant.
Could I ask a favour and could you pull out the salient parts of the posting so that its easy to understand the components required and the process involved, so that you have in effect a component (possible sourcing) and assembly instruction leaflet, that would make life much easier for those of us more technically challenged. So I could hand it over to an auto electrician to build and put in my car. Last thig I want to do is fumble around this sensitive PCB and cause myself a problem that I currently don't (touch wood( have.
Many thanks in advance.
22 Plus Four KIMI
12 Plus 4 Sport OZZY
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
Rog #817351 11/02/25 08:35 PM
Rog Offline OP
Thanks John,
I did post a list of the key items earlier in the thread, see below. That and the interconnect diagrams should be enough for a proper electrician to come up with a solution, I would have thought. But please don't view this as the "how to". As said before there are many ways this could be tackled or simplified using different switch types and relay configurations". It's just my attempt. Any solution will have it's pros and cons. Deejay proposed a nice push button switch alternative that was a direct replacement for the original PCB switches I believe. This would simplify the conversion negating the need for the toggle switch mounting assembly that I made up.
Originally Posted by Rog
Anybody - please check that these are correct for you, should you commit….
Toggle switches
https://www.ebay.co.uk/itm/335010744882
https://www.ebay.co.uk/itm/263616528665
Heater fan switch.
https://www.ebay.co.uk/itm/294842780517
Not really an auto component. It’s actually from a domestic room heater. However it appears to fit nicely. It eliminates a relay too. Time will tell how it holds up compared to the original 60's radiogram, band changer wafer switch (I did order spares). However it’s switching function is curious, at least to me. It appears to have a double wiper thingy, but works the blower ok. Take a look at my original diagram, I’ve attempted to draw it symbolically. It has no radial stop either.
Power diodes
https://www.ebay.co.uk/itm/222791829898
and
https://www.altecautomotive.co.uk/10-amp-in-line-diode-duritealt0-834-10a-5466-p.asp
15 way header to connect to the dashboard sub-harness connector
https://www.ebay.co.uk/itm/361377225738
9 & 12way Molex MLX connectors
https://www.ebay.co.uk/itm/265869939784
Pre wired 12way cable set to fit Morgan warning light PCB
https://www.ebay.co.uk/itm/184811333594
Current limiting resistors for both white and red LED’s
https://www.ebay.co.uk/itm/261964679700
Relays. These are cheap, plenty of others available…
https://www.ebay.co.uk/itm/131348827790
Relay bases. The ones that I used appear unavailable now, but these might be a good alternative
https://www.altecautomotive.co.uk/p...minals--altrelh45b-wt-1-09br-17299-p.asp
Flasher
https://www.altecautomotive.co.uk/12v-electronic-flasher-unit-altfl3-1-02-2338-p.asp
I also used Altecautotive for all of the smaller pits and pieces. They have a good selection of wire too.
Roger
Rog #817357 11/02/25 10:01 PM
Thanks Rog, at least I know where to look if the inductors fail laugh2
For now though, everything is back working, so for £200 with a spare set of gauges thrown in for free, that'll do me for now thumbs
Anyone need a blue painted dash thinking
