2 members (MK3, Bitsobrits), 210 guests, and 78 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 2 of 7 1 2 3 4 5 6 7
Hamwich Offline OP
Originally Posted by Paul F
pleased to see you back Tim.
Thanks Paul. Been more than a bit busy with other projects.
A dial micrometer with tube inserted into a spark plug base. This was screwed into centre plug two stroke cylinder head to determine piston position btdc for setting ignition timing on contact breaker points. Used with battery and light bulb in 1970s.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
I like this thread. Here's a variation: what do you reckon these tools are for ? (clue: not a Morgan....)
My Morgan ignition key!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Here's another very infrequently used tool. Clearly an instrument, can anyone guess it's primary purpose?
Sometimes it's enough just to own such beautifully made instruments.
TBM Offline
Google has told me it's a vintage tachometer, but that's a far as my knowledge goes!
One on ebay for £20 if anyone fancies one smile https://www.ebay.co.uk/itm/295936430444
TBM Offline
I've got a whole stack of very specific tools that probably I've only used once or twice, but made the job much much easier - spring clamps. rotax engine locking tool, MT500 bearing press, MG rear brake cylinder tool, Kawasaki Fork seal tools, Land Rover hub nut spanner, AN braided hose stuff.......
That's what I last used it for TBM, measuring the idle speed of a vintage Lister JP2M diesel in my narrowboat. It mechanically counts the number of revolutions over a preset period of a few seconds then the needle freezes with a read out. Primary use was measuring lathe leadscrew speeds for thread cutting. It came with a full set of printed tables for such.
Hamwich Offline OP
Certainly is. That's lovely, isn't it?
I just can’t bring myself to get rid of tools, some of which I’ve owned for over 50 years.
So: AF & Whitworth Socket Sets and an Imperial Micrometer, along with a selection of BA fasteners, still grace my toolbox.
oldgit
Bud
4/4 - Stanley
budster
Bud
4/4 "Stanley"
