12 members (MartinB60, Grumpy2, BobtheTrain, ScotiaSteve, DickJ, Moggo, Vansrv6, Alan Patterson, DaveW, RichardV6, Luddite, MJF),
350
56
Topics49,860
Posts837,493
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
Some advice sort. I am going to install a Summerhouse in the garden, what are your thoughts on sprayng the underside of the floor with Dinitrol ?
Posts: 22,359 Likes: 353
Posts: 22,359 Likes: 353 |
Made of wood presumably? Well, I don't see why not. With any timber construction I think the vulnerable places are at the ends of the main support timbers, so make sure they get covered.
When I replaced my fence posts I soaked the bottom few inches in oil before concreting in.
Posts: 5,587 Likes: 603
Posts: 5,587 Likes: 603 |
As Dave says .... end grain of any planks and timbers best soaked til they can't take any more.
Posts: 8,675 Likes: 491
Posts: 8,675 Likes: 491 |
Keith, the pukka way is to use Tanalised joists for the base timbers, if you have to cut any to length, soak the ends in Ensele
Ensure you have some form of cross ventilation under the floor, trapped damp air will trigger rot
1 member likes this:
Hamwich |
Indeed .... hopefully the summerhouse manufacturer included tanalising in the underfloor at least.... and the timbers were cut to length before treatment rather than the company buying treated timber then cutting it to their design. As you say, can't beat good ventilation!
Ensure you have some form of cross ventilation under the floor, trapped damp air will trigger rot There is a 10 year warranty on the floor bearers. It's being laid on concrete slabs.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Soak them in Creosote, get a local friendly farmer to get some of the proper stuff from his local merchant.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Soak them in Creosote, get a local friendly farmer to get some of the proper stuff from his local merchant. Won't that make the inside of the Summerhouse a bit smelly for the first few years? I'm definitely in the 'lots of air flow' camp. We built a log cabin back in 2007, none of the timbers were treated in any way (although it was high-quality Scandinavian timber) and it's still completely sound as there's a good 250mm air gap underneath.
Posts: 1,947 |
Preferably lay the wood floor on top of slate pads or roof felt. Last time I checked creosote was not available.
