Topics49,839
Posts837,303
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Nice. I got an ali version from SiFab Not so sure that I’m happy with this new stainless T today. Should have got a Sifab ali one…  Out of curiosity today I measured the voltage between the T and the ali rad cooling fins. It was showing around 1v, which is about 3 times more than the other stainless pipework in the cooling system is generating (there are many grades of stainless with a range of different noble potentials). Now I’m suspecting that introducing this grade of stainless is not an ideal mix for the longevity of my super expensive ali rad from a galvanic perspective. I could well be wrong... but have ordered up an aluminum T anyway. ![[Linked Image]](https://tm-img.com/images/2024/02/14/T-volts.jpeg) Now that Si-fab is no more, where do you source from? Can’t see any on Fleabay or carbuilder.
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Roger 2011 Plus 4
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
I've got to get around to changing that T this winter. Rog does the link show the size required?
If I can't buy a welded one I shall make one, but my tig welding is not too good so I might take the fun way out and make from solid.
I’ve just ordered this one John. As far as I can see the link shows it. Fingers crossed it should be ok! My internal hose diameters are around 16mm. ![[Linked Image]](https://tm-img.com/images/2024/02/14/ali-t.jpeg)
Roger 2011 Plus 4
Rog, thanks for the info.
Posts: 199 Likes: 1
Posts: 199 Likes: 1 |
I collected mine from the garage where it had its latest mot......guess how many miles it has done in the last 12 months...
Richard S 1993 4/4 1966 VeloSolex
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Much appreciated, Rog. However, will wait and see how it fits before getting one. I saw them on fleabay when looking but was a little wary of the diameter of the barb versus the more tapered, multi barbed designs. The Viper ones suggested by Geoff are multi barbed though a tad more expensive., when adding on postage etc. Be good to have a report back when done. Thanks.
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
I would go with the Viper multi barbed one. Plain ones with just the one lip can be difficult to get a water tight seal on especially with old hoses.
Be good to have a report back when done No problem Doug. Don't think it will be an issue. It’s the same shape/profile as the other spouts the hose connects to on the car - thermostat, header tank, head outlet manifold etc.
Roger 2011 Plus 4
