1 members (Montegue),
367
47
Posts837,277
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Be good to have a report back when done No problem Doug. Don't think it will be an issue. It’s the same shape/profile as the other spouts the hose connects to on the car - thermostat, header tank, head outlet manifold etc. Interesting concept this, which I think few people would have considered. FWIW, I measured voltage between the top of my sifab aluminium radiator and the OEM stainless pipe that runs across the top of, and parallel to, the camcover. I got 0.44 Volts! I don’t know much about the detailed science of galvanic corrosion, but googling around, it would appear that 0.25 volts is seen as a critical figure. However, in one article from “Allied Corrosion Industries” it listed the 4 requirements for galvanic corrosion to occur. It stated that you need: Anode Cathode Both to be immersed in the same electrolyte There must be a return path for electronic current flow, also known as the “metallic path” So from that, the fact that we have rubber pipes between anode and cathode, in the absence of the metallic path, is it really a problem? Any contributions from experts welcomed. My ali rad and top pipe shows about 0.3v. That will decay too, particularly if shorted. So I guess there is some chemistry happening. Probably dependent on the electrolyte/coolant condition too. Would also be very interested to find out if some clever person knows for sure. I don’t know how the physics plays out with respect to the system level ‘galvanics’. It’s complicated so am airing on the safe side with my new ali T connection. One thing I do concur with is the 0.25v safeish figure from a galvanic design perspective regarding material selection. It’s always something that needs consideration and very dependent on the operating environment, that’s basically where I’m coming from. It’s only anecdotal but on my first ali engined Duratec car, I lost two copper/brass cores in a relatively short succession before I changed to an ali rad (I think that CU/brass rad arrangement may have had an earth path). On both occasions the cores sprung multiple powdery pinhole leaks so have been super cautious ever since.
Roger 2011 Plus 4
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Be good to have a report back when done No problem Doug. Don't think it will be an issue. It’s the same shape/profile as the other spouts the hose connects to on the car - thermostat, header tank, head outlet manifold etc. Interesting concept this, which I think few people would have considered. FWIW, I measured voltage between the top of my sifab aluminium radiator and the OEM stainless pipe that runs across the top of, and parallel to, the camcover. I got 0.44 Volts! I don’t know much about the detailed science of galvanic corrosion, but googling around, it would appear that 0.25 volts is seen as a critical figure. However, in one article from “Allied Corrosion Industries” it listed the 4 requirements for galvanic corrosion to occur. It stated that you need: Anode Cathode Both to be immersed in the same electrolyte There must be a return path for electronic current flow, also known as the “metallic path” So from that, the fact that we have rubber pipes between anode and cathode, in the absence of the metallic path, is it really a problem? Any contributions from experts welcomed. Surely the path of conductivity can also be the coolant water + antifreeze which has intimate contact with everything we're concerned about corroding, I once wondered about adding some Fernox as I've found this very effective in stopping internal corrosion in multi metal central heating systems
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
I had a new piece of toughened glass cut to shape and fitted it in the frame. I was lucky in that the little screws holding the frame together came out easily.
1956 Plus 4 4 seater
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Surely the path of conductivity can also be the coolant water + antifreeze which has intimate contact with everything we're concerned about corroding, I once wondered about adding some Fernox as I've found this very effective in stopping internal corrosion in multi metal central heating systems In essence I would agree Jon. However it seems the best galvanic protection in engines is to use de-ionised water and/or anti-freeze inhibitor as the coolant, which you probably already have. The former cannot act as an electrolyte as it doesn't conduct so important to top up only with that. FWIW I'm so unconcerned I'm not even going to get out one of my multimeters
Posts: 132 |
Today, I managed to start my Morgan.
On Sunday, I managed to leave my dashcam plugged in and completely flattened the battery. 24 hours reconditioning with a CTX 5.0 charger (amazing product) and started within a second :-)
My MOT was due on Monday, so today I was changing oil, and spark plugs.
The plugs as the AA engineer had taken them out to inspect them, as she was having trouble starting, even connected to the AA van's battery. The plugs were looking a little tired, and I've not had a new set in a while. She certainly seemed to start and run more easily.
Posts: 132 |
I once wondered about adding some Fernox as I've found this very effective in stopping internal corrosion in multi metal central heating systems I'd be worried about how heat stable Fernox is at the high temperatures in a car engine. Yes, I know it runs through a boiler, but modern boilers don't run hotter than the flow temperature...
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Surely the path of conductivity can also be the coolant water + antifreeze which has intimate contact with everything we're concerned about corroding, I once wondered about adding some Fernox as I've found this very effective in stopping internal corrosion in multi metal central heating systems Yes, but as I understand it, the coolant is the path which will conduct current from anode to cathode, but for actual current to flow, (and corrosion to take place) we need a complete circuit and that’s where the metallic return path comes in, to complete the circuit to allow current to flow from cathode back to anode. So, I don't think we need to worry too much but looking at Rog’s experiences from the past, conclude that for peace of mind an aluminium tee might be the best choice, at least to get a good night’s sleep.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
I moved the 4/4 to access my 2 stroke strimmer. So far, attempts to start the strimmer have failed.  Bud 4/4 - Stanley
Bud 4/4 "Stanley"
Posts: 1,242 Likes: 30
Posts: 1,242 Likes: 30 |
I have been told that 90% of the time, that strimmers won't start, is caused by the two stroke petrol mix having "gone off"
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Clean & gap the plug. Change the fuel & clean the filter.
