0 members (), 310 guests, and 31 robots.
+8Rich 93
Posts837,277
#796225 21/02/24 06:22 PM
At some point in her life, Little Red had been retrofitted with a highly modified Ford Kent crossflow with a front sump pan. One of the problems is that there was oil starvation on hard right turns, so we decided to remedy the situation while the engine is out for a refresh. This is the set-up that Marc has had success with in a few other cars, so we went with it. Baffles, flapper doors and a horizontal fin to keep the oil from "sliding" up the side of the pan. Pretty sure this is a problem solved...
You just need to buy a Crossflow 'Big Wing" sump or copy and modify your own.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
This modification has worked in a Lotus Elan race car with the same oil pressure loss problem, so I should be good to go.
That's a neat job. It's useful to know that something that simple works well. I should do that mod to my Elan really.
2 members like this: Graham, G4FUJ, 1854sailor
