7 members (James B W, Robbie, Liam1961, nick w, MJF, Pittsartist, John Wilcox),
243
63
Posts837,271
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
At some point in her life, Little Red had been retrofitted with a highly modified Ford Kent crossflow with a front sump pan. One of the problems is that there was oil starvation on hard right turns, so we decided to remedy the situation while the engine is out for a refresh. This is the set-up that Marc has had success with in a few other cars, so we went with it. Baffles, flapper doors and a horizontal fin to keep the oil from "sliding" up the side of the pan. Pretty sure this is a problem solved... ![[Linked Image]](https://www.tm-img.com/images/2024/02/21/Oil-Pan1.md.jpg)
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
You just need to buy a Crossflow 'Big Wing" sump or copy and modify your own.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
You just need to buy a Crossflow 'Big Wing" sump or copy and modify your own. This modification has worked in a Lotus Elan race car with the same oil pressure loss problem, so I should be good to go.
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
That's a neat job. It's useful to know that something that simple works well. I should do that mod to my Elan really.
2 members like this:
Graham, G4FUJ, 1854sailor |
