At some point in her life, Little Red had been retrofitted with a highly modified Ford Kent crossflow with a front sump pan. One of the problems is that there was oil starvation on hard right turns, so we decided to remedy the situation while the engine is out for a refresh. This is the set-up that Marc has had success with in a few other cars, so we went with it. Baffles, flapper doors and a horizontal fin to keep the oil from "sliding" up the side of the pan. Pretty sure this is a problem solved...
![[Linked Image]](https://www.tm-img.com/images/2024/02/21/Oil-Pan1.md.jpg)
