Put more fluid in the master, drove it today and it flickered once. Checked the level, it looked full, but I noticed that the max fill line is above the seam in the tank, you can barely read it. I filled it to that level, and did not get any flickering on a 20 minute ride. The switch appears to be very sensitive to fill level. Also as a note, there is a test button on the lid to the master cylinder reservoir. If you push the button with the ignition on, the brake failure light will illuminate. Cheers to all for the help.
