Topics49,911
Posts838,147
Posts: 1,062 Likes: 156
Posts: 1,062 Likes: 156 |
Dave, is that a bi directional pot? If you swapped it for a regular single direction long shaft pot, with a switch incorporated, it might all fit neatly in place of the Lorin switch. Then you would have full control using the standard knob. ![[Linked Image]](https://tm-img.com/images/2024/02/29/pot-switch.jpg) Wow, what a super neat solution that would be  Great idea Rog, I'll investigate
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
Much more analogue solution, but I fitted one of these https://www.carbuilder.com/uk/fan-speed-conversion-switch-three-positionI already had a three speed fan on the aftermarket heater, but the fan was so powerful that even on the lowest setting it was cooling the heater matrix. I fitted it into the lowest fan setting, and now get a consistent warmth from the heater. It does mean I have a 5 speed fan setting!
Posts: 177 Likes: 12
Posts: 177 Likes: 12 |
Just took the switch of the car and after some continuity testing can confirm.
Fitted to my GDI is a 3 position 4 pole switch.
I tried connecting Poles A & B together and confirmed that positions 1-6 then had a single pole.
I didn't understand the discussion around combining poles to provide more Amps, and I don't know at this stage how many Amps I need, I will need better (Waterproof) Fans and probably will go for 2, I just had 1 for testing, so will continue along the Relay route to be safe.
So next thing to do is get a wire through to the fuse box and re-solder the leads to the right positions, then the Switch and Dash can go back together.
Mark 2015 +4 Ferrari Le Mans Blue
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Mark see below, specifically the 4 pole 3 way variant you have proven you have. ![[Linked Image]](https://i.imgur.com/kgpG0Yf.png) If you were to connect poles A, B, C, D together. Then connect positions 1, 4, 7, 10, then 2, 5, 8, 11 and so on for position 3, you would end up with a single pole 3 way switch. Because the current was split four ways though the switch would handle 4 amps. You require 4 positions though so the 2 pole 6 way switch variant with the mechanical stop set at position 3 would be a good choice. You could still double up the two poles and four positions as above to achieve 2 amp current handling. Hope this makes sense.
Posts: 14,750 Likes: 158
Posts: 14,750 Likes: 158 |
I have an idea to replace the 2 speed switch with a 3, but I'd like to keep the original Knob on the new switch so want to take it off to measure up before buying a new one. I have this little sketch left over from when I was butchering my dash. The switch shaft diameter is 6.3mm ![[Linked Image]](https://tm-img.com/images/2024/02/26/knob-size.jpg) This switch might work? Worth mentioning that these wafer switches only have a switch rating of around 1A and on the Duratec (don’t know about the GDI) it’s switching the negative side of the relay coil. This was demonstrated to me by the mechanic at Borghi's after I had burnt out the circuit board and was part of the incentive to change my dash. When the fan is running at high speed and you turn the engine off you see the various dash warning lights fade slowly because the spinning fan motor becomes a generator and feeds power back into the system. It almost makes one wonder if the heater fan system goes back to when cars had a positive earth system  Part of Borghi's dash fix was to reverse the wiring to the fan to the more conventional system so that power goes to the fan from the switch/relay rather than the fan constantly having power and being earthed via the switch/relay. I don't know the technical details of how this was done.
Hi, Any ideas why positions 2 & 8 have been connected? 2 is Fan position 1 (low), nothing connected to 8. ![[Linked Image]](https://tm-img.com/images/2024/03/03/IMG_20240303_112449.jpeg) I want to move 2 to 3 so should I also move this connection?
No idea Mark. All the connections I've seen just use the A pole ground (black), position 2 fan slow (blue) and position 3 fan fast (yellow or slate).
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Ditto - Is that a secondhand switch I see, that might have been used before? PS – Mark, be super cautious modifying your car…
Roger 2011 Plus 4
It almost makes one wonder if the heater fan system goes back to when cars had a positive earth system  Part of Borghi's dash fix was to reverse the wiring to the fan to the more conventional system so that power goes to the fan from the switch/relay rather than the fan constantly having power and being earthed via the switch/relay. I don't know the technical details of how this was done. The fan motor itself cannot have a permanent live connection Peter since there are two speeds each requiring a switched positive feed. It's only the relays that have permanent live feeds to their coils allowing ground/return triggers, one each for fast and slow fan selection. Ground triggered relays tend to be the norm now.
This was demonstrated to me by the mechanic at Borghi's after I had burnt out the circuit board and was part of the incentive to change my dash. When the fan is running at high speed and you turn the engine off you see the various dash warning lights fade slowly because the spinning fan motor becomes a generator and feeds power back into the system. I wonder if that was the reason they poked these two diodes (on later cars) into the high/low motor feeds, in an ‘attempt’ to suppress some of the motor’s back EMF and protect the PCB? ![[Linked Image]](https://tm-img.com/images/2024/03/03/fan-diodes.jpeg)
Roger 2011 Plus 4
